Question about KitchenAid KHMS105EBL Microwave Oven
No power to microwave,but outlet has power - KitchenAid KHMS105EBL Microwave Oven
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';'';';';
Posted on May 20, 2011
Microwave has power but doesn't cook
There could be significant problems that would merit returning your microwave oven to the store.
Jul 13, 2017 | Oster Microwave Ovens
Microwave stops randomly on its own, dispaly flickers and I get prompted to enter clock settings, what should I do to fix it
When a microwave asks for the clock settings, it has lost power. Check the plug and the outlet for damage or if it is loose. When on, vibrations can cause the plug to reposition if loose enough. Even a very short loss of power will reset the microwave. If the plug/outlet is ok, then check to make sure that the fuse for the outlet is tightened fully (breaker switches do not have this problem). Last, try another outlet as the wiring to the outlet may be loose.
Feb 11, 2012 | Danby DMW773 Microwave Oven
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
No power checked outlet and power is on
HELLO.
This is the way out of the problem.
The outlet is on power,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
Thanks .
I just bought a 1150 watt GE microwave. It worked in the store, but when we plug it in at home, in an outlet that we know works, we have no power. Could it be the outlet?
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement..
Hope it helps......
May 07, 2011 | GE JE2160 Microwave Oven
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
