Centrex CTW45270A 4.5 kg machine, washes but wont drain, i suppect the drain motor is stuffed, where can i get one????
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Are you in Australia?If you are I can help you.Please reply with additional information and I am sure I can help you.Pump could also be jammed or blocked.Did you remove the pump and check for objects?Looking forward to your reply.
Posted on May 18, 2011
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
WATER IS NOT DRAINING IN MY LG TOP LOADING WASHING MACHINE
The first thing I'd check is the water pump if the timer's working ok...
Mar 06, 2014 | Washing Machines
I have a centrex CTW45270A washing machine and the water doesnt cut off
Before you call anyone I would check the drain hose and make sure that it isn't pushed too far down. Reason being is that if the end of the drain line is lower than the pump of the machine then you'll have a siphon effect and the machine will constantly drain and fill.
Jun 15, 2012 | Washing Machines
Hi , washing machine is a lg intellowasher 7.5 kg it wont run any cycle with drain or spin was having to do both of these programs manually to get washing done screen flashes OE or O3 what is wrong with it...
Sorry but I don't know your particular machine so I am guessing with you saying 'it wont run any cycle with drain or spin'
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP ANY WATER!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Hope this is the problem and good luck!
John C
Feb 11, 2011 | Washing Machines
My lg washing machine is a semi automatic model 6.2 kg . water is not getting drained don't know why?
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Apr 09, 2010 | LG Washing Machines
Not draining
you will have to remove water pump, its on the other side of the where the drain tube goes in the machine. you should be able to clean it
Jul 30, 2009 | Washing Machines
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
My washing machine wont empty or spin it was working the other day and i put a small rug in it that went heavy when it was wet and it stopped working it is a centrex 7 kilo
You drain pump may be full of the rug stuff you will need to open the washer and the remove drain hose to remove what is stuck in the pump.... I have used a shop wet/dry vaccum put on the drain hose to remove stuff... but it will not always work...
good luck
Sep 12, 2008 | Washing Machines
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
