Question about Ed Hardy EHS 024 Sunglasses
Lense split exactly at center along the indent where the nose bridge is. Can this be replaced or repaired? What cost?
  • 24 Answers
Did you buy these glasses recently and still have the bill? Was there a warranty? How did you get them damaged? Did you buy them at an optician? In this case bring them there and try to make a complaint. According to my experience a damage like that cannot be repaired, but if the damage has not been caused by impact like somebody stepping or sitting on them, and the glasses are quite new you may succeed in getting them replaced. Wish you all the best!
Posted on May 24, 2011
My nose bridge is falling off on 1 side of my Nike skylon ace ev 0525 003 prescription sunglasses can it be replaced? If so how much?
Take it to any optician shop Mary and they will fix it for you. The bridges on my reading glasses cost $5 to replace and takes 5 minutes.
Apr 03, 2016 | Nike Skylon Ace EV 0525 Sunglasses
Brocken lense and nose piece
Looks like it is dead. Get something new. Repair can cost you more. and time consuming.
Apr 17, 2013 | Nike Clothing Accessories
N64c trigger leak
Trigger leak is easy to repair. Your nailer uses a valve # tva6 and is sold on ebay or many other web locations for about $20(generic valve works good also). To remove the valve, remove the trigger by removing the pin (3mm). Now remove the pin/s holding the trigger valve. With gloved hand apply air to gun and catch the valve as it pops out. Use caution because the valve could come out with force. If you would like to try to repair the valve, remove two pins holding the valve together. The center spool has three orings. The middle oring is usually the problem. It is a bull nose vinyl ring that splits. You could try replacing the oring with a normal oring, however it must fit very tight to work properly (no need to replace any of the other orings in the valve). I have successfully used regular oring instead of bull nose(purchased from Lowes plumbing department). Good luck
Sep 11, 2011 | Air Tools & Compressors
Brokin front corrector plate (front lense, need replacement)
Celestron can replace that corrector plate but you will not like the cost. Call them to get the exact cost but I believe it is about $750. The corrector plate must be matched to the primary mirror and then collimated on an optical bench.
Sorry but this will not be a low cost repair-- call Celestron here:
http://www.celestron.com/c3/page.php?PageID=37
Jul 19, 2011 | Celestron Optics
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
My sigma af 70-300 mm has stopped autofocusing.is there a simple fix or do I need to send it in for repair and about how much will it cost to get it fixed
For you to get this fixed by a lens professional it could cost you anywhere from 60 to 70 dollars but if the auto focus has stopped (and this is not new for these lenses and i have heard stories before) the manufacture will most likely warranty it for no cost to you
Mar 01, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I need two replacment nose bridge pads for a Kate Spade 135 EMME 1/S KADP. Where can I get them?
you can get the nose pads from any opticians, and they only cost a few pence each,
hope this helps
Feb 03, 2011 | kate spade Emme Sunglasses
How can you make your nose look smaller with make-up?
Use concealer on the bridge of your nose and use a power on top... I saw it on Oprah.
Use an eye shadow that is a little darker than your skin, and put it on the sides of your nose to make it look thinner. An eyeshadow with a slight green tint will help minimize the appearance of depth around the edges, thus creating a smaller appearing nose.
Buy a thing of powder that's two or three shades darker than the powder you put on the rest of your face, and brush it on the sides of your nose.
I used to do make-up and costume design for theater. The advice above is spot-on: you want a color a few shades darker on either side of your nose. To make your nose look even thinner, use a color a few shades lighter than your skin right along the top of your nose, down to the "ball" --the part that sticks out the most. If you're trying to create a curve to your nose, ie, make the bridge seem like it sticks out less, use the same color that you used on the sides and blend it--gently!--over the bridge, then apply the highlight color just to the ball and blend thoroughly. Less is more here: in Theater, we heap the makeup on so that the audience can see it under the bright lights. In the real world, you want to go very easy on it. If you use too much, or too dark a color, your nose will just look dirty.
Make sure the foundation and concealer you use is matt making your nose appear less shiny and less attention will be drawn to it, also make your eyes, cheeks stand out that way the attention will be drawn to your nose. I have a fairly large nose and just for the past year what I've been doing is taking blush, and rub it gently up and down the nose. but don't touch the sides at all, this will make your nose appear thinner and more narrow than big.
Added an illustrating related link. It's easier to understand by seeing a picture or video.
Another way is to draw attention away from your nose, all you need to do is to apply more make up to your eyes.
Nov 22, 2010 | Health & Beauty
I have a pair similar to the EV0253 and the rubber on the nose piece bridge has disintergrated due to interaction with sunscreen. Can I replace the nose bridge piece?
hi
you can certainly replace your nose piece bridge by taking your cool sunglasses to the show room where you brought with the bill they have given you but you should have warrente or you need to pay for it but it wont cost much . or you can vist the site below ,for reparing your sunglass
http://eyewearus.com/pd.asp?prod_id=10918&txt_brand_id=174&cbocat=1
Nov 18, 2010 | Nike EV 0253 Sunglasses
Fokusing ..
Service Manual maybe is not the best solution, because in this manual there is no info for repairing the optical unit. Replacing the lens unit part number: 175892511 is the only solution. Cost for the optical is about 100 Euro (for my account) If you need more info, please advice. Arpi
Feb 08, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Ed Hardy EHS 024 Sunglasses Logo
363 people viewed this question
Top Ed Hardy Clothing Accessories Experts
Da Doc
Tom Chichester
Are you an Ed Hardy Clothing Accessory Expert? Answer questions, earn points and help others
