Question about Canon PC-940 Black and White Copier
Canon PC 940 Copier
Can you tell me where the meter is on a Canon PC 940 Copier? It is driving me crazy.
Thanks Very Much!
  • Canon Expert
  • 1,326 Answers
Don't let it put you over the edge.. It will never be found... It has an electric counter or none at all. I believe you hold down the STOP/ CLEAR botton and it flash's in the copier count display
Posted on Sep 10, 2008
Hi sir. my canon pc760 suddenly does not turn on. it is not the fuse in the socket. pls advise on what might go wrong.thanks
when you open the back side of copier there is power supply in the power supply there is preventing fuse. you can change it easily
thanks
Nov 25, 2010 | Canon PC-940 Black and White Copier
Canon copier 940 trouble code EO?
Odds are that you are getting a error code E000. It is saying that you have a problem with your fuser unit. You can try to unplug the copier for a short time. But you will mostly need a new fuser unit. Good Luck
Sep 07, 2010 | Canon PC-940 Black and White Copier
Canon PC 940. replaced a $6.00 roller because bushing broke. Now I get code "EO". any ideas
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Aug 19, 2010 | Canon PC-940 Black and White Copier
NEED TO FIND OUT HOW TO GET A PRINT OUT METER READING FOR CANON NP6112.
You can not get a print out from a analog copier.... Only a digital copier can do it.
Apr 08, 2010 | Canon PC-940 Black and White Copier
Where is the fuse on the canon pc-940 copier. It
Why would a fuse have any thing to do with a clicking sound? If the fuser or fixing unit was having a problem you would get a error code. Have you replaced the toner or drum cartridge any time? If so, was the noise there before? If it was not recheck the installation and if you put the old parts back in and you have no noise, it has to be the new cartridge.... Good Luck
Oct 14, 2009 | Canon PC-940 Black and White Copier
Says there is a paper jam but there isn't
if the machine goes straight into jam code once switched on, its usually a good sign a sensor has broken or it has fallen out.
canon tech
Mar 26, 2009 | Canon PC-940 Black and White Copier
PC 940 Canon Copier help with cleaning
Hello sir; Discharge corona unit dirty it cause this problem, got to be discharge corona wire covered by tone, clean outby rubbing alcohol,it will take care your problem.
Feb 17, 2009 | Canon PC-940 Black and White Copier
Canon Copier
If your model is the one pictured, we can do it in Copy-Tech, Mayaguez. Call 787-834-0028 and ask for directions. State your model number and the symptoms and we will tell you if the fix is worth the trip.
Oct 09, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
138 people viewed this question
old marine
old marine
