We have 2 problems with our Windows XP system. Everytime we turn on the computer we get: checking file system on c: This type of teh file system is NTFS. One of your disks need to be checked for consistency. We allow this to run - computer restarts & everything appears to work fine. 2nd. problem: We are unable to do a System Restore. We have tried several dates listed in Bold print going back for several days and over a month. We always get the message: Changes made to drive L: after this point cannot be reversed because the drive was either excluded from system restore monitoring or was turned off or removed. We proceed with the restore & everything appears to be going fine - but, when the computer restarts after the restore we get this message: Your computer cannot be restored to "date that we set for restore". Software Dist. Service 3.0 No changes have been made to your computer. The System Restore shows that it is only monitoring C: I do have an external hard drive that shows to be L; drive. I only use this for back-up to my docs, photos, & music. I "safely remove hardware" after every backup. Do you have any suggestions on how these problems can be resolved?
    President:
  • 2,666 Answers
You do not need to use the safly remove hardware function for your external drive, just turn the ;power off and then unplug it.
I recommend you do a checkdsik and repair which will take longer than the consistancy check but will attempt to repair any errors it finds and works 99% of the time.
To do this copy and paste the following into a command prompt window.
chkdsk /r
It will ask if you want to run the next time windows starts- press y and then enter. Restart your system and allow it to run.
Posted on May 17, 2011
No boot
Turn on a working computer with its keyboard plugged in and test if the keyboard is working properly.
If it is, shut down that computer, unplug the keyboard and plug it into the system that is suffering from the missing "NTOSKRNL.EXE" file.
Turn on the system to see if the replaced keyboard resolves the problem.
Press the "F8" key right after the system initializes the boot sequence and before the Windows logo shows up to bring up a menu of boot options.
Choose the "Last Known Good Configuration" option with the arrow keys and press the "Enter" key.
Insert your Microsoft Windows installation disc.
Restart the computer and press the "R" key on your keyboard once you reach the "Microsoft Setup" menu.
Choose the operating system that you wish to repair, type in your admin password when prompted and press the "Enter" key.
Type "bootcfg /rebuild" and press the "Enter" key to rebuild the Windows "boot.ini" file, which may also resolve the issue.
Type "chkdsk /r" and press the "Enter" key to scan the entire hard disk for errors.
Type "exit" and press the "Enter" key to exit the "Recovery Console."
Restart your computer and see if Windows boots properly.
Feb 17, 2014 | Computers & Internet
My computer was running slow one day so I decided to do a system restore. During the restore process, my computer overheated and it shut down. Now everytime I go to turn on the computer, the gateway and...
MAy be You have deleted the Operating system and also the Operatiing system files.
ALong with You may also have deleted the Files needed for System restore . accidently .
Please try to load the OS with teh cd which you may have received along with .
May 27, 2011 | Gateway 7330GZ Notebook
I have a Dell Inspiron laptop. Windowsroot system32 ntoskrnl.exe appeared following a System Restore and I cannot use System Restore to try another date as I cannot get into Windows. How do I solve this?
You need the recovery disc to resolve this issue:
Boot from the recovery disc and select "R" to repair your Operating System.
If you're already in teh Recovery Console, select the Operating System you wish to fix and type the administrator password or just press enter.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 (here I presume that the CD is in D: and XP is installed in C:\Windows)
If it already exists, you will then be prompted if you wish to overwrite the file. Type Y and press <Enter> to overwrite the file.
Type exit and press enter and reboot your computer.
System should boot to windows this time.
Jun 13, 2010 | Dell Inspiron 6400 Notebook
Startup program not found
go to start menu -> run type there 'msconfig"
then press "emter"
then you see system configuration utility
Go to last option then disable all
then apply and restart computer then check.
Jul 29, 2009 | Microsoft Windows XP Professional With...
Is chkdsk working>
what operating system are you using? i have had this problem with windows xp. if you have the windows xp disc then you need to use it to repair the missing files on your hard drive. just put it in and start your computer and then follow the instructions to repair.
Dec 25, 2008 | E-Machines eMachines Desktop PC
Hello. Simply need XP drivers for e-machine model W4682 so XP can be reloaded from scratch. Vendor site is useless. Any info would be helpful.
here you go this should be all your drivers.
Modem Description Riesling Modem Driver File Type Original Driver Version 7.4.5.50 Operating System Windows XP Driver File Download (1.44 MB)
Chipset Description Intel Chipset Driver File Type Original Driver Version 5.0.2.1003 Operating System Windows XP Driver File Download (2.65 MB)
Video Description Intel 845GV Video Driver File Type Original Driver Version 6.14.10.3722 Operating System Windows XP Driver File Download (7.15 MB)
Media Reader Description Universal 8-in-2 Media Reader Software File Type Original Driver Version 1.08 Operating System Windows XP Driver File Download (4.40 MB)
Audio Description Realtek AC'97 Audio Driver File Type Original Driver Version 5.10.0.5320 Operating System Windows XP Driver File Download (16.70 MB)
Network Description RealTek Onboard LAN Driver File Type Original Driver Version 5.606.811.2003 Operating System Windows XP Read Me File Download Driver File Download (2.20 MB)
hope this helps if this isnt the correct series its the w-468 series drivers
Jun 18, 2008 | E-Machines Computers & Internet
Windows does not start successfully
Boot to safe mode. Then log in as administrator. Open My Computer, rightclick on C drive. Click properties. Select Tools and then click Error Checking. Select (Automatically fix file system errors) and then click start.
It will ask that you restart the computer. Upon restart it will run a check disk and if there are any file system error that may be affecting your boot up problem, it will fix them. If that was the problem, it should start up after this process. If not then let me know so we can try something else.
Thanks,
Lolita
Apr 09, 2008 | Microsoft Windows XP Home Edition
C0000218 (Registry file failure)
Windows cant access required registry files
if you have a xp cd, put it in, start the setup, and enter repair console.
In repair console you should see a
c:>
prompt, type cd windows
cd repair
copy *.* c:\windows\system32\config\
type exit after files have been copyed, overwrite if asked.
type exit
restart pc and try to start windows if this fails
go back to xp setup and perform a repair installation.
Mar 27, 2008 | IBM ThinkPad T20 2647 Notebook
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION
To resolve this issue, use one of the following methods.
Use the Recovery Console Tool
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
In Recovery Console, change to the c:\Windows folder.
Type cd sytem32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
Oct 23, 2007 | Computers & Internet
Access prohibition
Sounds like system and registry files may be damaged. Firstly if you have not got a windows xp cd go to double click My computer>tools>folder options>view and uncheck 'hide protected operating system files'. This will allow windows to see the system cache, but even this may be corrupt and you will require a copy of Windows XP for the required files. Now run this programme, go to Start>run then type sfc /scannow (there is a space after sfc and the forward slash). Press enter and it may require a restart to run file checker. If the files in the cache folder are corrupt it will ask for the cd.
Jan 24, 2007 | Acer Veriton 6800 PC Desktop
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
