Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a whirlpool cabrio agi it keeps saying uL. i make sure that everything is even but it keeps saying uL
  • 555 Answers
SOURCE: My Whirlpool keeps flashing and
UL means the load is unbalance. Open the lid and rearrange the clothes. If the problem continues, then the machine may have a problem caused by rust. If the unit still under warranty, contact the manufacturer for assistance on repairs.
If the appliance is out of warranty and you are a handyman (That works with safety), you may try a repair as indicated by a FixYa Tech:
"open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load."
Source: Tellmer
Posted on Nov 23, 2010
SOURCE: My whirlpool cabrio washer will not stay balanced
the repair man says i need to replace the inner tub for 299 dollars with a total price of 424 and its only 4 years old
Posted on Jan 19, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool cabrio model # wtw6300sw1
Redistribute the load to make sure it is balanced or run a spin cycle without load then see how the cycle works. The next thing to check are the suspension rods. Those are the rods that connect to the four white ball joints and the tub. The rods and springs should be intact and the assembly must be properly attached to the tub.
Post back the result of the inspection for further troubleshooting advise if necessary. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 14, 2010
  • 2468 Answers
SOURCE: cabrio washer with uL code. Will not operate
if it went thru the mini-cycle to redistribute the lad of clothes and it continues to flash uL then open the lid and manually redistribute the load,if this doesn't correct the problem,then try unplugging the unit for 15 minutes to re-set the ecu control unit and re-plug in and retry it
Posted on Nov 18, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: whirlpool cabrio got ul code which i sometimes got
Sorry to read about your problem, I hope this helps you out.
unplug/plug machine, if does not clear you may have a defective sensor....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
I have a whirlpool cabrio platinum and it will not spin the cloths out. it keep flashing ul no matter what i try to do?
Hello!
UL message means unbalanced load. Turn off washing machine, wait for door to open and remove half of the clothes. Then try again do make a spin. If it's still displays UL error shoul mean a loosen drive belt or worn carbon brushes on the washingh machine
Feb 26, 2018 | Whirlpool Washing Machines
Whirlpool cabrio top load washer ul on final spin
It senses that the lid is unlocked, even if it isn't. Could be a defective interlock.
Feb 24, 2018 | Whirlpool Washing Machines
My whirlpool cabrio has water trapped in the wash basket. Is this normal? Keep getting UL code and checked everything else.
I have the same issue. when I remove the wash basket from the tub the plastic parts all seem to have a lot of water trapped inside them. I am looking for a solution and may start my own question. not getting any fault code at all the washer runs as designed. but the dirty water trapped in the plastic top of and bottom of the wash basket is making the clean clothes smell like a dirty dish rag.
Sep 05, 2012 | Whirlpool WTW6400SW Cabrio Washer
I need an owners manual for my wacher whirpool cabrio agi WTW 6200 SWO
Have you tried WWW.whirlpool.com , at the bottom of the home page for whirlpool is a section labeled Owner Center, in that section is an area labeled Manuals and literature. Try there.
Dec 31, 2011 | Whirlpool Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio waher will not spin on the last 12 min of the cycle...it displays ul everytime...it is not unlevel we have checked
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops during wash cycle
my cabrio agi washer will stop constantly during the wash and rinse cycle and it will say F51 and dL
Sep 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal De
