I have windows xp and haven't encountered a problem until the last few days when windows wouldn't load properly or my computer would just freeze up shortly after windows had loaded,or would work as normal but freeze up after I had left it on standby for a short while.
  • jhorge cruz May 11, 2010
    How long will it freeze and do you have a lot of documents and files saved on your computer?
    Master:
  • 397 Answers
If this machine is a few years old the most common problem is a failing power supply. The power supply starts to over heat and the internal switching breaks down causing it to not supply the correct voltages where neede (usually to the ram).
Power supply's are ver easy to test with the correct tool, if you have a PC repair shop near you ask them for a quote to test your supply and to fit a new one should yours prove to be faulty.
Posted on Aug 14, 2008
  • Richard Finch Aug 14, 2008
    Well, what was inappropriate in my answer. Inappropriate is used for answers that are abusive or out of context. I think I gave you a solution. Please remove the rating. Thanks
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
My HP netbook keeps freezing. I don't know whether its due to overheating. But everytime when it freezes, its very hot. Another problem is, when i shut down my netbook, it always restarts by itself....
Hi xinyi pang17,
I have heard of this problem many times and it is usually due to overheating and motherboard problem. But first thing that you need to check is if the fan is working properly or not. You can use a canned air to blow out dust and accumulated particles from the fan.
However, freezing may also be caused by faulty processor. The unit may freeze (and overheat) while booting up, while using the computer or before the operating system loads if the processor is failing. To verify if the processor is failing, just access the BIOS (Basic Input/Output System) setup and test if it will overheat from there. If it does, surely the processor and/or motherboard needs to be replaced.
Hope this helps.
Jun 10, 2011 | HP Mini 1000 Netbook
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
My Computer will turn on and go to the windows XP loading screen with the blue bars and will won't load up, it rarely does but when it gets to the log on user screen it freezes
Right after your POST screen goes off,before you get to Windows starting,try pushing the F8 key several times until you get the Windows boot options.Then try 'last known good configuration".
If that doesn't work,you can boot from the Windows installation disk and try to repair your Windows installation.Let me know what happens.
And good or bad, please rate my post?
Bob
Aug 11, 2010 | Dell Microsoft Windows XP Home Edition
Error loading operating system - Windows Xp
If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Or Use a Windows Media Center Edition Version
Nov 18, 2009 | Acer Computer AOA150 Notebook
Upon rebooting the computer of our gateway, windows 98 xp media will not load,,, we receive a black screen that describes: We apologize for the inconvenience, but windows did not start successfully. A...
hello there
here are a few links that just might be able to help you out ok
best regards michael
  1. Annoyances.org - cdrom media, does not identify (Windows XP Discussion ... ... tips, fixes, workarounds, and answers for Microsoft Windows XP, 2000, Me, 98, NT, and 95 ... on "my computer" and will not load into any audio program. ...www.annoyances.org/exec/forum/winxp/1073187041 - Cached
  2. Adobe - Web Players Broadcast and media. Education. Financial services ... (1) Not officially supported by Adobe. Shockwave Player (System Requirements) Windows 98/2000/XP ...www.adobe.com/shockwave/download/alternates - Cached
  3. windows xp will not load windows xp will not load : Archived from groups: microsoft.public.windowsxp. ... Tom's Hardware: Topic windows xp will not load ... Windows Media DRM cracked ...www.tomshardware.com/forum/59109-45-windows-load - 62k - Cached
Sep 14, 2009 | Office Equipment & Supplies
NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
Computer startup and running issues
Hello:
Try to remove the graphic card and then clean with soft clothe and then insert it again and test.
if same problem encounter, you need to replace the video card, since your pc is virus free.
considering the monitor, you need also to change the or test the monitor but its 10% that this a cause of the symptoms.
most probably the graphic card got faulty.
may this help,
melnavz
Sep 03, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
