Question about LG LHD45EL Dehumidifier
The compressor does not kick on - this is the second one I have purchased in the last couple of years and believe there must be some things I can check out on my own. I only run it during the summer months in the south.
    Brigadier General:
  • 4,736 Answers
Yes, there are some things you can check.
The first thing to check is the setting on the Dehumidifier. If it's above 60%, it's not likely that the compressor will turn ON, as 60% is a pretty high humidity level. Keep in mind, if it's set at 60% that's what it will maintain, not remove. Lowering the level to 45% will have a much bigger effect.
Now, let's suppose, after turning the setting down, it doesn't cause the compressor to turn ON.
Take the unit into the bathroom, plug it in and turn it ON, with the Humidity setting at 45% or lower. Turn the shower on, using hot water and on the way out close the door. DO NOT run the exhaust fan in the bathroom. Wait about 15 to 20 minutes, return to the bathroom, turn the shower OFF and check the water collection bucket for water. If any water is in the bucket, your unit is working as it should.
Routine Maintenance:
Check and clean the air intake filter regularly. A clogged filter causes the compressor strain to keep up. Also, cleaning the coolant coils prior to using it in the Summer, can go a long way. After cleaning, a light coat of WD40 really helps.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 17, 2011
How do I determine reason that my Danby Dehumidifier isn't cycling on to compressor for more than 3-4 seconds at a time? Fan always runs but compressor only kicks in for 3-4 seconds then back off.
I would say low on gas or bad switch/thermostat.
The compressor probably has a shutoff for low freon. You would need a set of gauges to check for that.
Bad thermostat? You'd need a ohm meter.
User error? What kinda settings or controls do you have on the control panel?
There was a recall on these in 2014 for catching on fire.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Jul 16, 2015 | Danby DDR6009REE Dehumidifier
I have H. Bay model HB40F dehumidifier. It does not seem to ever actually start the compressor. There is a plastic box on the side of the compressor that contains a couple of coily looking things. It...
It is probably the start device(the coil looking things), as long as you don't hear the compressor humming. A loud hum is a lock compressor and the cost would be far greater than a new unit.
Jun 17, 2011 | Soleus Dehumidifiers
I have a dehumidifier that runs but does not pull moisture from the air in the basement. the application is about 3-5 years old. It is a Maytag and I purchased it at Home Depot. The Model is M3DG30B2A A....
There are a couple of things you can check for and they are; First of all, when you say the unit is running you may only be hearing the fan run. The compressor may possibly be not running(if it isn't running you will have no dehumidification as a dehumidifier is really nothing more than a small airconditioner.(cooling a coil for the moisture in the space to condense to). Second, The space may be to cool for the unit to run and dehumidify well, The space should at least be 65 degrees or warmer. Third, the system may have a leak and it is out of or low on refrigerant(freon). Depending on what you paid for the unit and if it has any remaining warranty(parts only-labor not covered) if the system is out of refrigerant or if the compressor is bad it probably isn't worth the cost to repair.
Nov 09, 2009 | Fedders A7DH65B2A Dehumidifier
The fan runs constantly. The compressor starts,
Check the compressor run capacitor first.
Jun 21, 2009 | Kenmore 53701 Dehumidifier
Will run but won't take moisture out of the air
Fedders, the maker of the maytag dehumidifier, went bankrupt and they are not honoring the warranties. call this number and if it is still under warranty, they will send you a prorated check for the remainder of your warranty. 1-866-629-8241. we had two months to go on our warranty and they gave us $14 and change.
Jun 01, 2009 | Maytag M3DH30B2A Dehumidifier
It sounds as if the fan motor is running, but the compressor is not.
Apr 05, 2009 | Maytag M3DH30B2A Dehumidifier
Compressor does not start
some of these units have a 5 year compressor warranty on them including labor worth calling sears and seeing if it does have the 5 year on the sealed system
Apr 09, 2008 | Kenmore 53509 Dehumidifier
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
LG LHD45EL Dehumidifier Logo
145 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
