Question about Ovens
The heating light under the lid on my holagen oven needs replaced, how do i do it.
    Scholar:
  • 52 Answers
Charliedaze
Need more information on the issue, is this light for the oven or hot plate.
when working on electrical appliances ISOLATE THE MAINS POWER BEFORE OPENING
If the light is in the oven panel some models are part of the display, and the whole display would have to be replaced. If however the light is separate this can be replaced on its own, some models have a sealed LED, others have a small builb, on the hob the lights are usually sealed two wires are soldered to them, removal requires total dismantal of the rear of the hob and then a replacement soldered back in be careful of the polarity as incorrectly connected it will not light up. You can get parts from a local elecrical appliance store.
Or whitegoods.co.uk the model and serial numbers will be required.
Hope this is helpful
John
Posted on May 17, 2011
Oven doesn't heat up and no light symbol shows up on the indicator panel.
it sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Nov 03, 2012 | Bosch Ovens
Brand new oven, maytag, the oven won't heat up and
IF IT IS STILL UNDER WARRENTY DON"T TOUCH IT CALL THEM BACK , MAYTAG HAS MANY PROBLEMS BUT THEY ARE GOOD AT REPLACING UNITSTHATHAVE PROBLEMS , PLEASE LET ME KNOE WHAT HAPPENS IF YOU NEED ME TO CALL THEM GIVE ME THE INFO AND I WILL DO THIS BUT SHOULD BE OK
Dec 01, 2011 | Maytag Ovens
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven does not heat up the fan and light still work it is just under three years old what could be the problem the upper oven works fine. it is a whirlpool oven
If `the fan is working o/k, then you need to replace the oven element, located at rear of oven
Please rate my solution.
Thanks.
Aug 19, 2009 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
Mar 19, 2009 | Ovens
Smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
