Question about Yahoo Messenger
D3d9 file is not working - Yahoo Messenger
  • 2,574 Answers
Download d3d9.dll >>click here to download d3d9.zip and copy the dll file to C:/Windows/System32
-or-
Download and run d3d9.dll fixer tool! ->> http://www.dll-files.com/dffsetup_d3d9.exe
Posted on May 17, 2011
Faild to get proc address for D3DPERTRF_Set Options (d3d9.dll)
download this d3d9.dll file and extract it to your directory. Also use a system utility software RegInOut to fix this issue.
Dec 10, 2011 | Computers & Internet
Failed to load library d3d9.dil
Try downloading this file: http://www.dll-files.com/dllindex/dll-files.shtml?d3d9 and placing it in your System32 folder located at C:WindowsSystem32
Hopefully this helps
Thank you
Feb 28, 2011 | Skype IM
Failed to get proc address for d3dperf set options d3d9.dll while installing skype
failed to get proc address for d3dperf_set options (d3d9.dll)
Jan 30, 2011 | Computers & Internet
When i open this error is come failed to get proc address for D3DPERF_SetOptions (d3d9.dll)
The d3d9.dll file belongs to the DirectX 9 software and its main function is to add DirectX functionality to Windows games and other multimedia applications.
D3d9.dll Errors
Many of the d3d9.dll errors occur when you have older version of DirectX on your PC. For instance, you may receive d3d9.dll errors, similar to the ones listed below in case you try to run a game that is specifically written for DirectX 9 on a PC that uses DirectX 8 or some other older version.
hope this helps
Jan 13, 2011 | Computers & Internet
How do i fix: "Failed to get address for D3DPERF
YOu need to update your DirectX. If still the problem exists then use a system utility software to repair your windows corrupt files, registry files and fix different operating system errors. I would recommend you to use system utility software RegInOut. Hope it works for you.
Jan 07, 2011 | Microsoft Windows XP Professional With...
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Whenever we try to open skype a dialoge box apppears showing fatal error failed to load library d3d9.dll.
You will have to re-install the Skype application in order to get rid off the error.
Please follow the below step:
1. download and install the Revo uninstaller application online(It's free).
2. Look for the "Skype" application and select the "uninstall" option.
3. Select "Advance" scan and remove all the remaining files of skype.
4. Reboot the computer.
5. download the d3d9.dll file from the following website http://www.dll-files.com/pop.php?dll=d3d9
6. Copy the d3d9.dll file and paste it at the following location C:\windows\system32
7. You will have to register the dll file before installing the skype application. To register the dll file:
Click on "Start" menu and select the "Run" option or Simply Windows key+R
Then, type regsvr32 d3d9.dll and click 'OK" .
8. Once the dll file is registered, you can install the Skype application and continue using it.
I hope this should fix the issue.
Thanks, Vicky
Dec 27, 2010 | Compaq Presario 5000 PC Desktop
I install today the least version of messenger11. after i install i cannot open my yahoo messger... it said cannot d3d9.dl cannot locate... i already retry to install but its the same problem what should...
If you've already downloaded d3d9.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
  1. Restart your computer if you haven't yet.
    The d3d9.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
    Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
    Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
  3. Assuming the latest DirectX version from Microsoft doesn't fix the d3d9.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
    Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
  4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with d3d9.dll and a reinstall could do the trick.
  5. Restore the d3d9.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your d3d9.dll error, try extracting the d3d9.dll individually from the DirectX downloadable package.
  6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Applies ToThe d3d9.dll error message could apply to any program that utilizes Microsoft DirectX, most commonly video games. Any of Microsoft's operating systems since Windows 98 may be effected by d3d9.dll and other DirectX issues. This includes Windows 7, Windows Vista, Windows XP, and Windows 2000.
Dec 21, 2010 | Computers & Internet
I installed skype version 5.0. and after i tried to start it up on my screen appeared fatal error for d3d9.dll
you might have to download and install later/better copy of DirectX
hope this helps
Dec 05, 2010 | Computers & Internet
D3d9.dll
Well you can download from below, then put it in windows\system32\ Then START>>RUN>>regsvr32 d3d9.dll and enter to "Register" it. Do that as Administrator. www.dll-files.com/dllindex/dll-files.shtml?d3d9
You may have to re-install the application though.
Mar 13, 2010 | Capcom Devil May Cry 4
Yahoo Messenger Logo
196 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
