Question about Singer CE-100 Futura Computerized Sewing Machine
Bobbin problem continued. ....
Hello again Sorry for the delay, I'm not the swiftest with computers either! THe bobbin no longer hits the bobbin case and sews nicely in the sewing mode but the embroidery mode still makes a bobbin mess. :>( Karen
PS I didn't find any manual for my machine on that site.
  • 3,037 Answers
I replied to your original question thread at
http://www.fixya.com/support/t893277-needle_hits_bobbin
Please don't rate this solution as any rating not as a Fixya will bring my rating down which we strive to perfect
Posted on Aug 14, 2008
After adding thread to the bobbin the machine is now making a loud noise it was not making before. What could be causing the the loud noise?
you may have over wound the bobbin
the bobbin may not be inserted correctly into the bobbin case
May 17, 2016 | Sewing Machines
Needle hitting bobbin case
Try a brand new needle. Make sure it is the right needle for the machine and that it is installed correctly.
If the needle continues to hit the bobbin case, then there is a needle/hook timing issue. Take it for service.
May 16, 2016 | Sewing Machines
Singer scholastic
Open up the bobbin case and remove the bobbin and case. There may be something catching on the hook (random thread) that is preventing the motion. The bobbin case could be off-kilter as well. If that is not it, take the cover off the sewing head and see what is blocking the mechanical parts of the levers.
Jul 30, 2014 | Sewing Machines
Why does my cs6000i the needle hits the bobbin case put nicks in case and then thread snags in the bad area
If you are talking about the bobbin case (housing), it may be inserted incorrectly. Remove it and put it in again, or the needle isn't seated correctly. Once the bobbin case is damaged, do not use it anymore or you will continue to have problems. If you mean the bobbin, change bobbins and see if you continue to have problems, as you might have the incorrect size.
Jun 27, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Janome Problems
when you turn the machine off and on again, that clears the computer and helps it start correctly..
but if there is a problem, when you continue sewing it will show up
then check for the normal things like
rethreading the machine top and bobbin
new needle
make sure the bobbin is inserted correctly into the bobbin case
clean under the needle plate and in the bobbin area for lint
Nov 08, 2013 | Sewing Machines
The needle is getting stuck in the fabric on my Bernina 1008.
Sounds like it needs to be serviced. Needle should NOT be hitting the bobbin case.
Since you don't want to have it serviced, you might check to make sure the bobbin case is inserted correctly and that the bobbin rotates clockwise as you are looking directly at it in the case. Also, is you needle compatible with the fabric?
Jul 29, 2017 | Bernina Sewing Machines
Needle hitting bobbin case holder following loud needle breakage.
try these sites they might have a video that would help
youtube
fixsewingmachines.com
Apr 05, 2012 | Sewing Machines
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
My needle jams when it hits the tray the bobbin case is in. It looks as if the timings off because just to the right of where my needle hits is a dip in the tray. Almost as if the needle's too long. I've...
If this is a drop-in/horizontal bobbin, raise the needle to it's highest position. Remove the bobbin case then replace it so it fits snugly into the shuttle. Hand walk to see if the case moves freely in a circle. If it stops, it is not positioned correctly. You do not have to have a needle in to test this.
Once you are sure the bobbin case is correctly in place, re-install the needle. Hand Walk to make sure the case turns without any interference.
If the needle continues to hit, then the machine needs to go into the shop for service.
There is a DIY for adjusting the timing of the hook sewusa.com if you wish to try the adjustment on your own.
Mar 14, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Singer CE-100 Futura Computerized Sewing Machine Logo
41 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
