My epson stylus rx595 is printing lines on evrything how can i correct this issue asap
  • 1,536 Answers
I'm assuming these are lines going across the paper and are regularly spaced about the distance covered by one pass of the ink cartridge carrier.
The most common cause is a problem with an ink cartridge. The quickest solution is to replace the ink cartridge(s) if you have new ones on hand. Well-defined, one pixel-wide lines of a particular color are caused by a leaky ink jet (sometimes if the leak is severe they will spread out or have blotches along the line. Smeary lines are caused by lint on the bottom of the head. Blank lines, or lines missing a color, are caused by a clogged jet.
The next most effective solution is to clean the bottom of the ink cartridge by gently wiping it with a cotton swab soaked in isopropyl alcohol (available at drug stores). Unfortunately, most Epson printers will refuse to use a cartridge that has been removed and put back in the printer. You may be able to fool the printer by opening the cartridge cover, then pulling the power plug and USB cable as soon as the cartridges move to the middle for changing. Then you can remove, clean and replace the cartridges before your reconnect the cables. While you have the cartridges out, polish the electrical contacts on the cartridges and inside the printer, using a clean, soft white pencil eraser of the type typically found on mechanical pencils (especially if you are getting blank lines).
Occasionally, a blank line is caused by a bad connection between the traveling cartridge ribbon cable and the printer logic board. In this case, a new cartridge will have exactly the same problem as the old one. This can sometimes be repaired by disconnecting and cleaning the ribbon cable at the logic board if it has a removable connector with a pencil eraser. (Note - if the connector has a locking slide collar or flip-up latch you need to unlock it before pulling the ribbon; otherwise, the ribbon simply pulls out). Some printers use crimp-on fittings instead of a removable connector; the only thing you do for this is squeeze the crimps a bit tighter with pliers and hope it works. The hardest part is disassembling the printer so you can get at the other end of the cable. This can take quite some time, so you'll have to decide whether it's worth the effort.
Note: do not touch the electrical contacts in the cable or the cartridges with your fingers. Static electricity discharge from your body can damage the circuitry. Similarly, if you end up trying to clean the other end of the cable, avoid touching the circuitry on the circuit board, or the contacts on the cable if the ink cartridges are installed.
Posted on May 17, 2011
How do I turn off sleep mode on my EPSON Stylus Photo RX595 Series
it should do that by printing, or perhaps update driver on computer
Feb 28, 2015 | Epson Office Equipment & Supplies
I have feint lines across photos and have done head clean. Epson Stylus photo R220.
Well, here's your problem: that's a six year-old printer. I used to have it and and 2007 I replaced it with an Epson Stylus Photo RX595 AIO because like the R220, the RX595 has the ability to print directly onto inkjet printable CD's/DVD's. Your printheads/nozzles are shot and all the cleaning in the world will not fix them and it's certainly won't be cost effective to have repaired when you can get a current model for less than the repair price. Mine went after two years. Honestly, it's amazing that this printer lasted as long as it has. Six years has to be some kind of record.
Here are the current CD/DVD printing models from Epson.
http://www.epson.com/cgi-bin/Store/CDLanding.jsp
Apr 28, 2011 | Epson Stylus Photo R220 InkJet Printer
I have alot of jamed paper in my Epson Stylus Photo RX595 printer. I also have tore paper jamed in the printer per following the directions in the Epson manual. Please help.
ithink problem come from paper roller, maybe the paper roller is broken, or gear box of the roller is nor connect properly, contact srvice center to fix it
Dec 03, 2010 | Epson Stylus Photo RX595 Series
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
105 people viewed this question
k24674
