1996 BMW 318 Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the stepper motor - 1996 BMW 318
Randy Ohler
Level 3:
  • BMW Master 14,585 Answers
  • Posted on May 17, 2011
Randy Ohler
BMW Master
Level 3:
Answers
14585
Questions
8
Helped
3946853
Points
39683
It's called the Idle Air Control motor (IAC). It is on the side of the throttle body. This controls the idle speed. What it does is let in a certain amount of air into the engine, in steps. The more it is open the higher the idle speed. The ECM controls it.
Marvin
Level 3:
Top Expert:
  • BMW Master 85,242 Answers
Marvin
BMW Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057375
Points
266281
A stepper motor is a small DC electric motor used to hold a certain position of the shaft it turns or a piston, it is used in electronic speedometers that have a needle and also in other app's like the AC air ducts to move the doors that divert air. It is also used to control idle speed by moving a piston that diverts air around the throttle valve..
Stepper motor replacement - ford falcon egas with Vialle Gas Converter
Vialle LPG Converter Ford Falcon Straight Gas & Dual Fuel Stepper Motor. This is a brand new genuine Vialle stepper motor
I replaced iac sensor and it still shows bad.
Have to check powers and ground curcuit.
Idle Air Control Motor Circuit Malfunction Possible Causes Setting Conditions • Stepper motor connector is damaged (check pins for damage, and moisture) • Stepper motor Coil 1, 2, 3 or 4 circuit is open or shorted to ground • Stepper motor coil circuit(s) is shorted to voltage • Stepper motor has failed • PCM has failed Engine running; system voltage over 11.5v, and the PCM detected an incorrect voltage on one or more of the IAC motor circuits for 2.75 seconds with the motor enabled.
2answers
Speedometer is stuck at the bottom. Moves in opposite direction.
Many speedo dials on many American models seem to suffer an early demise. It usually turns out to be the dial itself which is faulty, so I'd recommend checking and changing this first
Oil pressure gauge is ready zero in 2003 2500hd 8.1 liter
Hello, this problem is due to a failing stepper motor. The stepper motor is the motor behind the gauge that controls the movement of the needle. When a stepper motor begins to go out it will cause the gauge needle to stick, skip around, stay at zero or max out on the gauge. The only way to fix the problem is to replace the stepper motor with a new one. While replacing one motor it is best to go ahead and replace them all as the others will go out in time as well. Your cluster will have one motor for each gauge. Here's a link to a page showing exactly how to replace a GM stepper motor and where to get the correct parts to do the job! DIY Finally How To Repair GM Instrument Cluster At Home Speedometer And...
Oil pressure gauge drops to zero and comes back up to 80
replacing one motor it is best to go ahead and replace them all as the others will go out in time as well. Youre cluster
1helpful
2answers
My speedometer started going crazy when stopped it says i am doing 75 and at 30 i am doing 120 how can i fix this problem
the speedometer clusters go bad alot you can take it out and have it repaired or replace it and have it reprogramed
3answers
Speedometer not working
it very well could be the instrument cluster, i believe ive heard of this before. shifting is ok? may want to call dealer with vin# and see if there is a service bulletin on this problem. i may do a search as well
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
