Ethernet Port Trouble
HI, I have a Dell GX260 computer been rebooted a few times, I tried to connect an ethernet cable but it doesn't show as a working or recognizable although the LED lights do switch on at the back of the computer..
I am trying to connect to a network and my internet. The ethernet wire definitely works and so does the router and modem.
  • 35 Answers
Install the drivers from here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&servicetag=&catid=&impid=
Posted on Aug 19, 2008
I am trying to install a printer to in my Dell Inspiron laptop 1545. I have the printer connected to the laptop through the ethernet port. But I can not get it to pull up the printer at all. Is the...
Hi lesstravelro...
No, the printer does not connect to the ethernet port.
Before you hook your printer to your laptop besure to run any softwear that came with the printer.
I would also recommend that you go to the Manufacturer's website for updated drivers for your printer.
Your printer will have a printer port or usb port on the side/back of the printer to plug the printer cable into the printer.
You will plug the other end of the printer cable into a usb port on your laptop.
Please take time to rate me thumbs up
Sep 21, 2011 | Dell Inspiron 1545 Notebook
I have a belkin router i am having trouble connecting it. i dont know where to connect the ethernet cable. Does it go the computer or the modem?
the ethernet cable should be connected to the ethernet port of the router to the ethernet/network port of the computer. you will also need to connect a cable through the router and the modem, then a phone cable from the modem to the phone line.
Aug 31, 2010 | Computers & Internet
Ethernet connection appears not to work, though Windows XP device manger says the device is ok
Try to use a known good ethernet cable. Check if lights at the ethernet card is lit up. check also on router if the indicator light will lit up when you connect the ethernet cable.
Mar 23, 2010 | Dell OptiPlex GX260 PC Desktop
Install ethernet card optiplex gx260
That slot is actuall not accessable externaly. The open bay is for the AGP slot right next to it. Directly to the left of that slot you have a riser board the provides 2 additional horzontally mounted pci slots. You'll have to use one of these.
May 11, 2009 | Dell Ethernet Card Network Adapter
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Integrated Ethernet Port Fried/Trying to Reformat
Try going into the BIOS when the computer starts up (F12 at the Dell Screen I think) and disable the onboard ethernet and see if that helps.
Jun 10, 2008 | Dell Dimension 2400 PC Desktop
Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Mar 18, 2008 | Dell 3000cn Laser Printer
I can't get my computer on the internet . I am using windows xp and the modem will not get the internet on the dell computer
Hi, This modem can be used via one of two ports: ethernet port (network port) or USB port If your computer has an ethernet port, it is perferable that you connect through this as you will have better performance. If you don't then you can get an ethernet card installed inside the CPU. If it's not possible to connect via this connection and you have to use the USB, then you will need drivers. This website gives you full instructions on how to use this particular modem and also gives you the USB drivers if needed. http://www.triadtwcable.com/template_media/cablemodems/rca245.htm Good luck! Lolita
May 08, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
