Question about Nokia N95 Cellular Phone
A fully charged battery cannot take me up to 5minutes and it will run down
    Top Expert:
  • Nokia Master
  • 76,070 Answers
The battery is worn out, you will need to replace it, they are avaiable on eBay very cheap and other online cell phone stores like the cell phone shop..
Posted on May 17, 2011
Charging battery compaq presario c700
If you can reach inside the computer and rub the battery contacts gently to remove the corrosion ,which is invisible , this will help greatly. Sometimes even a new battery will suffer the same. Clean the battery contacts also turn off the laptop and charge it fully do this on a regular basis. Say once every 2 months
Nov 05, 2013 | Computers & Internet
FS240BX battery how Long should it take to charge.
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
Jan 22, 2011 | Black & Decker Firestorm Slide Battery
I have a Rascal 305. How long should built-in charger run to fully charge batteries. Mine only charges about one hour at 3.5 amps (on meter on back) before shutting off. What should charging current be,...
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Sep 29, 2010 | Health & Beauty
After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
Laptop power connection faulty
Hallow Dear,
As your explanation about Battery issue simply I’m advising you to replace your battery with original one.
But before that there is one thing that you can try it out.
---Use your laptop until battery goes down & shutdown automatically then remove the battery and try to discharge it completely with small bulb manually
When it’s on completely discharge (0 Volt) keep it on Outdoor Sunlight about 12 hours.
After that connect it to your laptop & recharge it completely (until Computer LEDs showing you as Fully Charged)
****** REMEMBER DO NOT TURN ON YOUR LAPTOP******
Until its Showing you as fully charged
That will be nice if you can check Battery Voltage & Amperage manually as it is charged fully before turn on your laptop. (if not you can give more charging time accordingly)
This will not solve your any component (thermal fuse, vRegulate) problems inside your battery but will increase your battery Cells Life and most vStoraging problems on Cells inside your battery
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv6000z Notebook
Problem
How old is the battery? Have you let the battery run down completely and then fully charged it back up?
Was the phone a display model when you purchased it, or was it in an unopened box? How fast does the battery run down? Have you checked the owner's manual to see how much talk-time you get out of the fully-charged battery? Let me know... Thank you and hope to hear form you soon. billyho1977@FixYa
Sep 16, 2008 | Nokia 5300 Grey Cellular Phone
Battery Symbol and "charged" stay on iPod screen
You could try restoring the software back to factory defaults and see if something is missing. Make sure it is fully charged before doing it.
Aug 08, 2008 | Apple iPod nano
Nokia n81 running a new battery down in 6-8 hours on standby mode
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Jul 30, 2008 | Cell Phones
Battery is always dead
This is a common problem with the Q. It uses a lot of juice to run all of the programs. There are a few things you can do to help with this problem. First, Kill all of your running programs before going to bed. You can do this by selecting Start, then System Tools, then select the Task Manager icon, then choose Menu, then "Kill All". Since you will repeat this a lot it is a good idea to save the Task Manager program as a speed dial. Second, Make sure you are not overcharging you battery. When it is fully charged, stop charging. Charge it again when the battery runs all the way down. Then repeat. This will "reset" your battery. Third, make sure you have a second battery and a battery charger. When you go to bed at night, simply replace the battery with a fully charged one. Finally, try this...keep your phone plugged in at night. Then run it all the way down before you replace the battery. Reset the battery often as you lifetime for the battery will diminish the more you keep it charged all night.
Jun 15, 2008 | Motorola Mobility Moto Q
Nokia N95 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
