Question about Car Audio & Video
Im trying to wire my quantum qca 3000d monoblock 3000 watt dynamic power amplifier the right way
  • 8 Answers
SOURCE: how do i wire a qvc subwoofer to a 3000w 1ohm stable monoblock amp
depends on the amplifier if you have a mono block amp or a regular 2 output amp if it is 2 output make sure to bridge and that means the negative to one output and positive to the other output then need to find out the rms on the speaker. the amp should have the ability to adjust it you might want to get a digital multimeter set it to watts and make sure you only set it to the RMS of the speaker because max handling should be the 1800 and usually the RMS is half the max so it should be 900 w again it depends on the amp and were the adjusting knob is and or if it has one
Posted on Nov 05, 2008
etirbynnor
  • 655 Answers
SOURCE: How do i wire two 15 inch subs to 2 ohms
Hello familia_gome,
Those MOFO-15's have dual 1ω voice coils. So the only way you can get 2 of them to present a 2ω load is to use 1 voice coil on each one with the two of them wired in series. Using both voice coils, you can get a 1/4ω load by wiring the voice coils in parallel and then wiring the subs themselves in parallel. You'll get a 1ω load with the voice coils in series and then parallel the subs. Or you'll get a 4ω load with both the voice coils and the subs in series.
Here's a link to Power Acoustik's PDF for the MOFO's. I recommend that you check out the wiring diagrams on page 3.
http://www.poweracoustik.com/SUPPORT/MANUALS/PA-MOFOWoofer.pdf
Hope this helps.
Posted on Apr 07, 2009
etirbynnor
  • 655 Answers
SOURCE: How do i wire two fifteen inch subs to 2 ohms
Hello familia_gome,
If you have 2 subs that are 2 ohms, the final impedance will be either 1 ohm if they are wired in parallel or 4 ohms if they are wired in series. You cannot get a final load of 2 ohms. Unless your amp is stable down to 1 ohm (many amps are not), your best solution would be to wire the subs in series, positive of one sub to the negative of the other sub, and the remaining positive and negative to the amp. Yes, this will result in a 4 ohm load and the amp power will be reduced. But it is better than destroying your amp with too low of a load, and the subs will work fine, just not as loud.
Posted on Apr 11, 2009
mwoodring1
  • 496 Answers
SOURCE: Need to know how to
Instead of writing all the info you need I have included a link. It has ALL the info you need in regards to you speaker wiring. With picture the site will be easier to understand then me just writing it out for. your mono amp is easy to hook up to as it only has one output. Check out the site if you have any question please feel free to contact me and i'll be happy to answer them for you.
Please let me know if this site was helpful to and if everything is working right.
M.Woodring
http://www.diyaudioandvideo.com/FAQ/Wiring/
Posted on Jun 20, 2011
  • 18 Answers
SOURCE: i wont to no the
Google Search, Ebay, Craigslist are your best options.
Posted on Jul 12, 2011
Is my 1ohm 1 channel monoblock 4500 watts quantum amplifier to strong for my 3000 watts quantum subwoofers
If you are experiencing chirping or bottoming out the problem is you probably have your bass boost turned all the way up, your frequency responses probably turned all the way up, the speakers may not be able to handle that low of a Hertz, basically anytime you turn everything up on your amp you're going to get more and more disturbance this is most likely what you are hearing if you turn your bass boost down and turn your gain all the way down and the problem stops then this will be your solution, and it is an easy fix all you have to do is keep turning up your gain until you start noticing the Distortion then dial it back 10% you should never use bass boost on an amp it destroys the amp and definitely destroys the speakers
Jun 25, 2016 | Quantum Car Audio & Video
How many Watts is the A1300HCQ AUDIOBAHN amplifier
  • 2400W Max, High-Current Monoblock Car Amplifier
  • RMS Power Rating:
    • 300 watts x 1 chan. @ 4 ohms
    • 600 watts x 1 chan. @ 2 ohms
    • 1200 watts x 1 chan. @ 1 ohm
  • Max Power Output: 2400 watts @ 1 ohm
Dec 18, 2014 | Car Audio & Video
How many Watts is the a1300hcq Autobahn amplifier
A1300HCT Max Watts:
  • RMS Power Rating:
Quantum audio qca4000d mono block amp 4000 watts cosmic series. when car is turned off amp works fine. when I start the car protection light kicks on. Whats wrong
How do u connect a quantiam audeo 4000 monoblock wats with 15s q powers I tryed it but they do not sound da way I though they were going to sound let me no som thing thanks?
Nov 09, 2011 | Quantum Car Audio & Video
Hi i got two speakers clarion xw 1500 ,i`m looking for amplifier good quality and strong enought can supply power for two subwoofer speakers same time,please help me tomargos3@op.pl
The Clarion sub woofers that you have are 600 WATT RMS each, with a combined power handeling of 1200 WATT RMS. Your best option is buying a 1 ch Amplifier (monoblock) Anything in the region of 1000 to 1500 RMS will be more than enough. Brands that you should look at MTX, Phoenix Gold, Soundstream, MA Audio, Kicker, Hifonics, MB Quartz these are but few of the good quality brands out there in the mid to high end range.
If you are on a tight budget then a good alterrnative without a lot of compromise on quality versus cost then Quantum Audio, Crunch Audio, Kenwood will still do the job just fine.
If you are not restricted by budget. Zapco, Mcintosh, DLS and others are up there in the creme de la creme of car audio.
Another brand name that i have used that is not very well know (as far as i know) is Elemental Designs. They have a great monoblock amplifier that delivers all its power at 12V as oposed to most other brands needing 13.8V (V=Volts) and over, it is also suprisingly inexpensive for its quality.
I hope this helps you in the right direction.
Respectfully
dreamsystems
Feb 05, 2011 | Clarion XW1500 Car Speaker
I have an SPL Z1X 3000D Mono (3000W) amp that I just got so I could maximize my Sub's output. But My Kenwood 800W amp has better sound quality and is much louder. I don't know why
because a kenwood amp is true power and has better pertection built in it.the spl is a cheaper brand of equipment.just because it says 3000 whats doesnt mean it is,the spl is about 150 - 200 brand new,that should tell you why
Dec 12, 2010 | SPL Dynamics Z1X-3000D Car Audio Amplifier
No sound
try checking your fuses
Apr 19, 2010 | Kenwood KAC-X501F Car Audio Amplifier
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
