Question about GE Hammering
Is there any way I get print a new GE typical wiring diagram that is on our breaker box downstairs? (It also has a place on it to tell which breakers go to what, as well asw some Load Center instructions).
  • 70 Answers
The breaker box will need to be manually re printed, you will have to have some kinda portable light to plug into the sockets and a set of walkie talkies makes this job easier. start with the easy stuff , you big appliances they are the 2 position breakers in the box,manually switch the breakers to the off position untill you see the power go out,repeat untill you find them all.plugs in the kitchen and bathrooms are usually on dedicated circuits.If you cant find what a breaker does leave it off eventually you will find it,unles it is a 2 pole breaker good chance it does a major appliance
Posted on Jun 13, 2011
How do i install a 14-3 wire with ground to the breaker
Following wiring diagram is for general purpose household 120V-240Volt service.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-10-1000.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/Color-codewire.html
Why are you asking that question without saying what you are wiring? 120Volt, 277V, 480V etc?
What does rating plate say on device you are connected to 14-3 wire?
And what amp/volt/watt rating are you connecting to 14 gauge wire?
No electrician would omit that information.
14-3 wire is usually only for 3-way switches and other light duty applications.
Must be connected to 15 amp breaker and no larger.
Apr 08, 2013 | GE 15 Amp 1 inch Single Pole Circuit...
I need a diagram for a westhouse breaker box so i can see where the white red black and green wire goes
I'm not sure what you mean about 4 wires coming into your trailer.
4 wires is typical of 3-phase service, but typical trailer usually has single-phase residential service.
Copy following link to see main breaker box and component parts for single-phase residential wiring.
Aug 12, 2012 | Hardware & Accessories
Installed timer and I'm getting breaker pop. I've tried several different ways to wire and it keeps poping the breaker. GE Replacement Timer 15600
1) If you are replacing T103, the T103 can be wired many different ways. Not all wiring diagrams are supported by GE 15600 replacement timer that fits into Intermatic box.
2) Double check your T103 terminals
T103 terminals should be A 1 2 3 4
If terminals 3 and 4 have wires, then GE is not correct replacement.
You can buy repair parts for Intermatic timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
3) GE has terminals 1 and L which are connected by brass bridge. If brass bridge is removed, add a jumper wire and connect terminals 1 and L
GE has terminals 1-L X 2
4) Typical GE 15600 wiring shows on following link, in addition to links for parts and manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
White wires on terminal A connect to terminal X
Black wire on terminal 1 connects to terminal 1
Black wire on terminal 2 connects to terminal 2
Sep 11, 2011 | GE Vacuums
I have a new GE 15306 Mechanical Time Switch and need to wire it up to 2 white and 2 black wires that I had on my old timer. I need more information on the wiring than is on the diagram on cover of metal...
http://waterheatertimer.org/images/GE-15306-wiring-250.jpg
GE 15306 is a version of 120Volt Tork 1101 indoor-outdoor timer sold at Home Depot under GE name and number.
You have 2 cables.
One cable comes from Breaker box, and other cable goes to Load (light, fan, motor, pump).
Each cable has black and white wire.
1) Cable from breaker box: Black wire H Hot connects to to terminal L.
Notice there is a metal bridge that connects terminal L and terminal 1.
If metal bridge is missing, use a jumper wire and connect L and 1.
White N Neutral from breaker box connects to terminal X.
2) Cable going to Load:
Black connects to terminal 2
White connects to terminal X.
So both white wires are on terminal X.
Jul 14, 2011 | General Electric GE 56941 24-Hour Outdoor...
I have a GE Profile JT952series Electric Double Oven and the keypad is not turning on the bottom oven
Check your breaker box to make sure the breakers are ON.. these typically are double throw breakers.. it is possible one of them has been thrown open.. so flip that double throw off and back on.. then check..I have seen one side of these breakers fail.. unusual.. but it happens.. then a replacement is in order.. regardless. visually it may appear the breaker is closed..but upon closer inspection.. one side may be "spongy/open". There are always exceptions..so examine the breaker box carefully.
If one breaker is open..it would be wise to keep an eye on things to determine how it got that way in the first place. If the breaker will not close or throws/pops again..you either have a bad breaker or a wiring problem..in some cases the element may have grounded out..or burned a wire.. etc.
Next thing to check for is a bad element.. Remember..this is a 220volt hot circuit with a high amperage breaker.. BE CAREFUL.. USE CAUTION.. Failure to do so could result in serious injure or DEATH.
Turn off power at the breaker box to the oven.. test the working over to make sure the power is OFF.
Remove the oven racks
Remove the screws at the base of the element
Pull the element toward you
Note how the wire(s) are connected
Disconnect the wires.. checking for broken or lose terminals..if lose or broken..repair.
You will need a volt ohm meter for the following..
Test the Element for continuity. Place each probe on the terminal ends (manual will have ratings) generally if you have continuity it probably works..
Test for a grounded/short.. one probe to element the other to terminal end..if you have continuity.. it's shorted out. Test both terminals
Replace with a new one if needed.. reverse procedure. Turn on the power .. and test for proper operation.
Again.. 220 VOLTS..HIGH AMPERAGE.. USE CAUTION..not doing so could result in injury or DEATH
After you have done the above..and get an all pass..then it's on to controllers and temp sensors.
Best of luck
Apr 19, 2011 | GE Profile JT952 Electric Double Oven
How do i install a 14/2 wire into this particular circuit breaker
You hook the black wire under the screw in the circuit breaker and tighten it down...
Then hook the white and the bare ground wires to the neutral bar in the breaker panel...
It is usually easier to fasten the black wire into the breaker before placing it into the box...place the back or wire end of the breaker under the tab first and then rock the breker into the box and firmly push it onto the bar
heatman101
Feb 23, 2011 | GE 15 Amp 1 inch Single Pole Circuit...
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Baseboard heater connect
I have a fahrenheat F2548 baseboard heater, there were not any wiriing diagrams or installation instructions in the box where can I find the wiring diagram,
Aug 04, 2008 | Fahrenheat Electric Convector Baseboard...
Electric hot water heater 40 gallon ge
Typical H2O heater with 4500 watt elements should draw around 18 amps. Check to make sure the connections for the wires at the breaker are tight, loose connections will cause the breaker to heat up. If all of this is good and the breaker is still heating up, it is time for a new breaker.
Jun 12, 2008 | Heating & Cooling
Hammering Logo
232 people viewed this question
Top GE Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Hammering Expert? Answer questions, earn points and help others
