Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
I have a Frigidaire FRS26F4CW1 works great but every month to month and a half it stops working for a few days then starts working perfectly. Symptoms: Fan blows fine but no cold air.Fridge side gets to room temperature while freezer somewhat stays cool but only because of frozen products that are in there.
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
Posted on Feb 17, 2008
SOURCE: My fridge freezer is working
front server not working. no light coming on for temp. water dont work but ice maker works
Posted on Mar 13, 2008
bobotfel
  • 236 Answers
SOURCE: brand new refrigerator...freezer works great, fridge does not
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
sample of air vent location :
Posted on Apr 07, 2008
22yooper
  • 828 Answers
SOURCE: my Frigidaire side-by-side fridge (model:
1. Check and clean the condenser where system heat is transfered to the air. Located in back behind removable panel, after cleaning make sure you re-install the panel for proper air circulation.
2. Check the back wall of the freezer for ice or frost. If you have frost buildup on the back wall you have a defrost system problem. This would be lated to the timer, heaters, or defrost thermostat.
Posted on Jun 03, 2008
SOURCE: The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Posted on Jul 11, 2008
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
DCR-HC32 NTSC the touch screen that controls the playback suddenly stopped working...help!
I've had this problem with my HC32 touch screen for a year and a half.
The fix was to buy a new camcorder which is working out great -- but every 6 months or so I have to get this one back out to use as my analog to digital video pass thru device.
To get the touch screen to work:
- I put it in the charger dock and turn it on AND LEAVE IT ON so the screen is displaying something (anything).
- within 12 to 24 to 36 hours it starts to work on it's own. At first it will only let you make a single menu choice and lock up again but a few hours later it will be perfectly normal for at least a few days (maybe forever if you use it regularly).
I've done this three or four times now and it has worked each time. It seems that after it sits a few months and the battery discharges the problem occurs.
Feb 22, 2011 | Sony DCR-HC32E DV Digital Camcorder
Fridge stops working and warms up for half a day then will cool back off and start working for a day or a few days. When it warms up everything in the freezer defrosts but will then refreeze a day later...
Check your defrost thermostat in your freezer access panel. Your defrost timer could be faulty, Your defrost timers ussually run for 12 hours and defrost runs for 30 minutes. That being said that is why I believe your timer is getting stuck on run and then eventually it finally gets unstuck and goes into defrost. Eventually it will get stuck in one place or another.
Aug 27, 2010 | Frigidaire FRS26H5AS Side by Side...
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Aug 18, 2009 | Frigidaire FMV156DC Microwave Oven
Machine will not start
We had a similar problem. I unplugged the machine for a few minutes. When I plugged it back in it started to spin. BUT! I it was a reacurring event. once I got the water to drain I follow the advice given by another on this site. Checked the drain pump, it was blocked by some quarters and towel lint. The machine has been working for the past 5 months without any problems.
deb
Oct 09, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
FRS26F4CW1 Freezer not cold, Fridge fair
yes you may need a relay or the compresser mybe locked up..let me know if you want help replaceing it
Aug 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire front load washer starts...then quits...
yes it could be but also it could more than likely be your pump not letting water out or not letting enough water out which stops the cycle try doing aload when it stops turn dial to empty and if it spins then your pump is faulty needs replcing thats the more common fault
Aug 11, 2007 | Frigidaire FTF530FS Front Load Washer
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
