My viore 50l4 turnes on then shuts off with two blinking lights lamp and timer what do i do
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Posted on Mar 26, 2009
Slinteriors
  • 8617 Answers
SOURCE: WD 62725 Timer geen light keeps blinking
Thats caused by the capacitors on the dm which wont allow the DM to boot back up because the power cord was unplugged to change the lamp. You can get the V26 DLP DM repair kit at the following link which will usually repair that issue and it contains the replacement caps and step by step instructions with detailed pics on how to do the repair on CD plus the service manual is also on the CD.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Posted on May 26, 2009
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
Posted on May 30, 2009
  • 64 Answers
SOURCE: mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Posted on Aug 01, 2009
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv comes on for about 20 seconds then shuts off and the timer and the lamp lights flash on and off
is a inverter board defective, and shutdown auto. needs to replace inverter board. send to repair.
Feb 14, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
Viore model:RPT50V24DX/SMS shuts off and LAMP light blinks
Turn your set around. Locate the square access panel located on the lower right. Remove the 4 screws. Remove panel. Then push down tab on cooling box, it will look similar to a horn. Lift and remove. Lamp will be visible towards the back. Locate the pull handle,it is made of strong wire and it will be folded sideways. Pull open the handle. Look for screw on the left side of the lamp. It secures the lamp in place. Remove the screw completely. Now pull the handle firmly and voila! The lamp will slide out. To install new lamp just reverse the process. NOTE!!! Do not touch the lamp with bare hands. It will damage it. Wear surgical gloves or handle with a cotton cloth...
Aug 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
