Question about Dewalt DW421 5'' orbital sander
When I use the sander, the velco-like thing underneath the paper gets chewed up looking. It's 2 days old, so whats wrong??
    Problem Solver:
  • 15 Answers
When using this kind of sander you have to let the machine do the work, meaning if you press on it things like that happen, if you aren't doing that then possibly too thin and cheap sandpaper attached.
Posted on May 19, 2011
How do I change the paper?
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.Refer more on custom essay writing service
Custom Essay Writing Dissertation Writing Thesis Writing with Free Draft...
Jan 09, 2016 | Tools & Hardware - Others
Looking for the manual,my paper slip off as soon as I start to sand the wood
There are a couple of different types of paper you can use with a sander. One with a sticky back and one that works is like velcro . Sounds like you are using the wrong kind of paper for your machine
Sep 04, 2015 | Tools & Hardware - Others
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
Jul 28, 2014 | Skil Tools & Hardware - Others
I am using the Porter Cable Quicksand Model 222 and the sander paper will not stay on the pad? What am I doing wrong...
first make sure you are using the right sandpaper for the tool and if it is hook and loop look at the pad for wear that will not allow the paper to adhere fully, if it is a PSA make sure the pad is not damaged.
Sep 07, 2011 | Porter Cable Tools & Hardware - Others
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
Re my Sears 3" belt
What did you use to make is smaller (to shrink?)
Is the back of the belt cloth or paper?
Dampness usually makes things stretch--
But too much moisture, and you tear easily, too!
Tell me more-
Mack B
Jul 04, 2011 | Vacuums
Good day. How do I insert sandpaper into the Makita 9035N sander? Thank you.
looked at breakdown for the 9035 and this shows as a half sheet sander with 2 clips, they have a lever that has to be pulled away from the sander to allow you to lift up on the clamp and insert the paper under the clamp jaws when finished inserting the paper just push the levers back to their original position. You can download an owners manual by going to makitausa.com and typing in your model number. Let me know if you need more assistance.
Jun 14, 2011 | Makita Tools & Hardware - Others
I have a Black & Decker sander, model # 7447 and am having problems changing the sand paper.
The 7447 does not have a release lever. To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Jun 13, 2011 | Black & Decker Garden
My 5 inch random orbital Sander: the self stick sanding disk will not stay on it. Can you tell me the trick to making them stay on sander? Thank you!
If your disks have a "furry" bottom you have to have something like velco stuck on the base of the sander. The velco is slf sticking and you get it at the hardware store. Good luck.
Jun 10, 2009 | Makita Tools & Hardware - Others
Dewalt DW421 5'' orbital sander Logo
168 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
