Question about Frigidaire Washing Machines
My daughter slammed the door shut on our frigidaire affinity model ltf6700fs0 breaking the plastic striker on the door. we ordered and installed a new part but the washer still doesnt work. It has a digital display that still says dr indicating a problem with the door although it seems to close fine.
  • raydenicsas May 18, 2011
    Thank you Kevin! Do you know if this is a part we can order and repair ourselves or do we need to call a repairman in? (Neither my wife nor I are mechanically inclined).
  • Frigidaire Master
  • 2,605 Answers
Hello, Welcone to FixYa. I'm not sure if you are aware of it, but the plastic striker is there to not only lock the door but activate the machine once locked. Chances are the latch/switch assembly was damaged as well and will require replacing too. The part can be had on-line or many local part vendors and It really isnt too difficult, the greatest challenge being the removal and re-fastening the door bellows/boot gasket spring. I do have a pretty descriptive instruction if you think you'd like to attempt it. Let me know what you find and I will help going forward any way I can. I hope that helps. Good luck. Regards, Macmarkus :)
Posted on May 18, 2011
  • Mark MacDonald
    Mark MacDonald May 18, 2011
    Hello again,
    Here is the additional info I said I could provide but was unable to from my iphone last evening. It should guide you in replacing the switch assembly.
    I know most folks will rule out the lock initially because the unit does indeed "lock", however, the lock on these machines are a two part device, a set of contacts to lock and a secondary contact to activate hi-speed spin, i.e.
    **Unplug the unit from the wall first...safety first**
    **The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
    You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace.
    As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
    1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER.**
    2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
    3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
    4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
    Let me know if you need further assistance going forward or if my instructions are not clear.
    Thank's again for visiting FixYa today. Good luck.
    Regards,
    Macmarkus :)
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
The problem is with the door lock assembly that also needs replacement. If that is bad the control detects that the door is open and so will display the error code. Please get back to me if you have any other questions.
Kevin
Posted on May 17, 2011
  • Kevin White
    Kevin White May 21, 2011
    Sorry for late response....was not around for a while....you can view this video and then decide if you want to replace this yourself:
Door on Frigidaire front load washer loose
have you tried this:
https://www.hunker.com/12000515/how-to-fix-a-sag-in-a-frigidaire-affinity-washer-door
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
Apr 24, 2017 | Washing Machines
How do I remove the filter on my front loading Affinity LTF6700FS0 to clean it?
Look at this video. The filter is in the black boot the runs from the tub to the pump.
Dec 05, 2012 | Frigidaire ATF6700FS Front Load Washer
Door open error shows even when door is securly closed. Is most likely a faulty door latch and lock mechanism, or sensor. Any suggestions to repair without calling in an expensive repair person?
here is a website that has the parts break down. it should be a striker and door switch/lock that are the problem.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151098&diagram_id=1238997
check to see if the door striker is ok it has two prongs on the door that go into the machine.
when the door is closed the striker goes into the switch.
hope this helps
Sep 01, 2011 | Frigidaire GLTF2940ES Front Load Washer
The door on my fridgidaire atf8000fs1 sags so it doesn't shut correctly. I've had to order a new door striker since the last one broke off. How do I adjust it so it hangs correctly?
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem.
After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time.
i got this answer at http://www.appliancerepairquestion.com/2013/04/frigidaire-atf8000fs1-washer-door-not.html
Jun 19, 2011 | Frigidaire Affinity ATF8000FS
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My washer door isnt staying locked
Your probably need to replace the door striker (two pronged plastic prongs) thats attached to the door with two screws, or, the door switch. The door switch can be accessed by taking off the top lid and removing the two screws in front of the machine. The switch is a whole lot more expensive than the striker. Be sure to pay attention on how the switch is wired!
Jun 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Closing the dryer door
you need a part number 5366021400 latch kit I think take your model and serial number to you local appliance dealer and they will probably have one on the shelf and its so easy to install just pull the old broken part out and replace with new one
Nov 15, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
