Question about Kenmore 63942 Dryer
Kenmore Dryer I have a kenmore 70 series dryer, it dries for about 10 minutes then i hear like a rattling noise and then the dryer only blows cold air... If I turn it off and let it sit for about 30 minutes I can turn it on and it will get hot for about 10 minutes again... I have to use this cycle to dry a load of clothes
  • 3 Answers
Your thermostat could have problem and it confused the temporature inside the dryer. You should change the thermostat. To make sure you can use VOM (vol-amp-milimeter) device to check it. If it reads 0, it means OK. If it reads another number, it is faulty and need changing a new one.
Good Luck
Posted on Aug 18, 2008
Fix rattly noise in gas dryer
could be coins in the baffles, sometimes coins make it into your dryer, and they slide under the baffles, remove or open the top of your unit and you will see the screws that hold on each baffle, remove the screws and the baffle will come off inside the dryer with whatever is in there. then re-secure the baffles..
Oct 24, 2015 | Kenmore Dryers
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 63942 Dryer Logo
130 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
