Question about HP PSC 1410 All-In-One InkJet Printer
Replaced ink cartridges on my hp 1410psc and now it wont print anything, check cart light flashing. and an E showing
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
It could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem .
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
Posted on May 18, 2011
My HP 6500 wont print black ink. It's like a very very light grey and I can't see it. Tried 2 new print cartridges and no luck. Please help.
The HP 6500 printer has separate in cart and print heads. The light print you are getting is because the print head in clogged with dry ink. First thing to try is to go into the printer software on your computer and do a print head cleaning procedure, this will take a few minutes to finish. You may have to run this several times to clear out the dry ink. If this does not solve the problem when you will need to get a replacement print head, the part number is CB868-30002
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
I just replaced the yellow ink cartridge but it
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jul 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
My printer wont print. The ink cart went out and then was replaced but the orange light continues to flash and wont print
replace the cartridge with a new one probably the cartridge is not good or malfunctioning!If problem persists disconnect the printer from power outlet wait for 10 seconds and connect again
Jan 20, 2010 | HP DeskJet 940c InkJet Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
I replaced the black ink cart. but the ink light still blinks. do i have to replace the color cart also? or what else could the problem be? thanks so much
Hi:
I would say replace them both, but first make sure you removed the print head protectant strip from the cartridge. Go into you printer properties and check your ink levels to see if the color is empty, also make sure you use HP ink cartridges, off brands do not meet the required spec's all the time. And never use ink refill for cartridges as sometimes the ink they use is to thick for the HP Printer.
Dec 02, 2009 | HP DeskJet 932c InkJet Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Hi hello
You must replace both ink cartridges with GENUINE HP ink carts..
Jan 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 5740 printer both orange lights are blinking and wont print
  • I replaced both carts with HP brand, no joy.
  • I cleaned the cart/printer connections, no joy.
An interesting aside is that if one or the other cart is removed, the appropriate LED goes out and the other blinks. At least some of the sensing circuitry sees the cart.
Anyone have a schematic of the cart/printer electronics?
Oct 10, 2008 | HP DeskJet 5740 InkJet Photo Printer
HP PSC 1410 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
