Question about Refrigerators
I have an Amana Refrigerator model SX25SW. The freezer does not seem to go below 20 degrees. How can I find out if it is the seal or if maybe the refrigerant level is low? Or perhaps it is another problem. The refrigerator just keeps running and never shuts off.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 20, 2011
Amana model sx25sw noise
it sounds like the fan is hitting the carboard shrowed it is made from paper and is probably colapseing that is the only thing that tuns on a fridge it is an electric fan
Mar 20, 2014 | Refrigerators
Freezer is at 20F
The louvre that let's the air into the freezer is probably closed nearly ll the way shut, thus not allowing the cold air in. The same compressor runs the frig and freezer. Find where the air is coming in and there is where you should find your problem.
Feb 03, 2013 | Amana Refrigerators
Wide variation in temperature in refrigerator section (40 degrees in top, 20 degrees in bottom, also, freezer set at WARMEST setting is ten degrees below zero.
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
Aug 17, 2011 | Amana Refrigerators
Freezer not getting lower than -20deg
Three things bad defrost time bad defrost termination switch or bad heaters. You need aservice tech to check this out. Russ
Jul 19, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
I have a 10year old Amana 25cu SRV26V side by side and our freezer and food area is not very cold. The freezer side is only 20 degrees. Both sides have been turned up to 7 as high as it can go since...
Hi: It's a sealed system so if you need a recharge it will be expensive. You mentioned that the "air filter" in the back was clean. Do you mean the panel at the bottom of the back of the refrigerator? The coils are on the bottom (parallel to the floor across the bottom) and have to be clean. If you haven't done this; remove the grill and vacuum the coils. It's best to use a coil brush to get to the very back. A refrigerator coil brush is available at Lowes or Home Depot. I use an air compressor to blow them out. Then I have to dust the house. If the coils haven't been cleaned this will cause what you described. I hope this helps, Jeff
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana bottom freezer refrig runs at maximum coolness
Thanks for your inquiry. I think I may have fixed it. I unpluged it and took everything out of the refrigerator and freezer, cleaned it thoroughly inside and out and unscrewed the back wall inside the freezer. There was a huge ice buildup on the coils so I let it sit for 12 hours like a defrost. I turned it back on and it seems to be working fine. It is not running constantly and is maintaining about 5 degrees below. If this doesn't stay working, I guess I have to call a repairman.
Feb 14, 2009 | Amana ABB1927DE Bottom Freezer...
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
