Question about Tascam MD-801 rmkII Mini Disc Player
Tascam MD 801R record 1 minute - Tascam MD-801 rmkII Mini Disc Player
2 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: mini disc recorder question
Just use the first two tracks, one for left and one for right and use the PAN pots to adjust the stereo positioning. Just run the 'tape out' or 'line out' or 'aux out' of the mixer to the REC "IN" on the MiniDisc recorder; hit "record" then the "play" button to start it. Make sure your input selector switch is on ANALOG and not DIGITAL or OPTICAL. Let me know how it works out for you. Okay? Thanks
Posted on Nov 06, 2009
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
Tascam md 350, lost remote need a pause is it possible
No. Just press STOP and don't worry about it. You can monitor in REC.
Jun 14, 2015 | Tascam MD-350 Advanced MiniDisc Recorder
How do I anticipate the overwrite modus
There should be an "END SEARCH" button on there.
Dec 03, 2014 | Tascam MD-350 Advanced MiniDisc Recorder
I have a tascam 564 i,m unable to eject the disk from the machine it only reads disc loading
I listed a similar answer for a similar qestion. If you have a push in to load mechanism, it is probably worn out. I had similar problems and found they were impossible to correct - think of it is an out of allignment or mechanical problem.
The few places which can fix this problem were charging $60 an hour plus shipping to and from, and may not have the parts to fix it. the cheapest way to go is to eBay for another MD.
If you are buying a used deck check it out like this - Load and record a good disc. Eject it and then replay it. If the reloaded disc plays you have a good MD if not you have a bad MD recorder of some sort.
Bad decks act like they are recording but MDs are not CD recorders they use a laser and a magnetic riding skate on the other side to of the MD write to the disc. If the skate is damaged they will appear to write but when you put the disc in another recorder or reload it to your recorder they will not have anything recorded on them.
I get bothered when I see clueless ads for used MD recorders saying it plays but does not record but it is a simple fix - It is not and the unit although it will probably play well it is not cost effective to fix the record problem I mentioned.
Feb 24, 2014 | Tascam Audio Players & Recorders
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
TASCAM MD350 After a couple of minutes in Record or Playback mode the machine switches off (display extinguishes). A while later it comes back on and starts playing the 1st track. This happens with...
Very strange- It sound like a thermal break int he soldering somewhere.
Either that or an intermittent short in a capacitor. I suspect that the problem will be back.
Jul 11, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
Tascam 8 track recorder won't play back recording
Does it use MiniDiscs? If so, it cannot work with standard audio MiniDiscs, it requires a special DATA MD.
Jan 21, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Mini disc recorder question
Dec 01, 2008 | Tascam MD-350 Advanced MiniDisc Recorder
Tascam MD-801 rmkII Mini Disc Player Logo
136 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
