New computer and can't get the printer to hook up with the computer
  • 43,501 Answers
To be able to help we would need to know what computer and what printer you are using..
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on May 18, 2011
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
Dell Dimension 4550 and HP printer 2410. Everytime computer is turned on, it detects new hardware and reinstalls the printer, and repeats the process again. After that, the printer seems to work OK.
disconnect the printer, go into device manager and delete all the printers listed there. go onto the printer manufacturer website and download the drivers manually then install them. Hook the printer back up.
Aug 25, 2012 | Dell Computers & Internet
What cable do I use to hook my printer to my laptop?
poundland sell the cable sometimes. failing that so do wilkos
Mar 19, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Sep 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I need to install my HPOfficejet J6413 All-in-One Printer/Scanner/Fax
YOU NEED TO INSTALL YOUR SOFTWARE FIRST...SO INSERT YOUR DISK...PLEASE MAKE SURE YOUR PRINTER IS NOT HOOKED UP TO YOUR COMPUTER YET...CLICK ON START...GO TO CONTROL PANEL...GO TO INSTALL NEW SOFTWARE.
(NOTE) SOFTWARE HAS TO BE INSTALLED BEFORE HARDWARE
AFTER SOFTWARE IS INSTALLED...YOU WILL WANT TO DO A RESTART...UPON RESTART...HOOK YOUR PRINTER UP TO ANY USB PORT...AGAIN... GO TO ...START...CONTROL PANEL...TYPE IN PRINTERS...GO TO INSTALL NEW PRINTER.
YOU'LL NEED TO DO ANOTHER RESTART...SO TOO MAKE SURE YOUR COMPUTER DETECTS THE NEW SOFTWARE AND HARDWARE. YOU CAN ALSO GO TO...PRINTERS...(FROM YOUR START...TYPE IN PRINTERS...SEE IF THIS PRINTER IS THERE? IF THERE, CLICK ON IT...GO TO PROPERTIES...DO A TEST PRINT!
NEED FURTHER ADDITIONAL HELP...PLEASE DON'T HESITATE TO CONTACT ME!
HAPPY PRINTING!
MARTIE
Sep 06, 2011 | HP Computers & Internet
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
I need to make the scanner available on the network, the printer is networked OK but can't seem to figure it out. Can you help
Need to know what printer and how it's hooked up.
For instance, if it's an all in one printer (epson or HP etc) and it's hooked up USB to one computer and shared across the network, you can't share the scan capability across the network.
What yu'd have to do is scan to the computer that it's hooked up to, placing the scans into a folder that is shared across the network so anybody can access it.
If it's a network capable scanner with it's own Ethernet connection, then the process can be vastly different, but the scan function should be sharable across the network.
Jul 21, 2011 | Office Equipment & Supplies
When I try to print. It says you must hook up printer . The printer has ben hooked up. I printed one paper just fine. the next time it said hooh up printer. I removed cable fom printer & computer...
It seems that your computer is not recognizing the printer even when it's hooked up. Make sure the cable is properly inserted into the printer and your computer. If you have another USB cable you can use, try that and see if it works.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
Jun 15, 2011 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 4200 all-in-one problem
I got my old printer hooked up last night. THANKS!!!!!!
Sep 10, 2008 | Lexmark X4270 All-In-One InkJet Printer
14 people viewed this question
k24674
jasbo
jasbo
