Question about HP Compaq Presario SR2011WM PC Desktop
I have a SR1517CL Presario and I am having a bear of a time getting an additional hard drive installed. How do I remove the green overlay on the rack? it is in the way of the screw holes to secure the drive.
  • HP Master
  • 11,800 Answers
Follow this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639864&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=501776
Posted on May 17, 2011
How to change hard drive
Here is a link to the Compaq service manual. It will instruct you on how to access the case and, and how to remove and replace the Hard Drive.
Remember that after you replace the hard drive, if it is the primary, you will need to reload the operating system using wither the support disks supplied with the unit or with the recovery disks you made at the time of purchase. Without those, you will not be able to operate the PC once the drive is replaced.
Link to Compaq Service Manual
Nov 11, 2013 | HP Compaq Presario SR1517CL (PX797AA) PC...
How to replace hard drive
open your casing, unplug the old harddisk, connect the new one, then you're done
How to replace hard drive in compaq presario desktop S4020WM
the green plastic "panel" as you call it...may have a clip that's securing the hard drive in it. see if there is a tab you can pull up (gently) with a finger that may release the drive
Feb 21, 2013 | Compaq Computers & Internet
My computer started freezing for no apparent reason and at random times. All scans came came back clean, and I had plenty of memory available. Now all of a sudden, when I turn it on, I have no video input...
I'd try playing with the graphics card - if it's a card and not on-board, try removing & re-inserting it. Also, try removing the card altogether and using the on-board video controller - if that solves it, the card may need to be replaced.
Also, try running a RAM check. You can use something like Memtest86 (http://www.memtest.org/): burn it on a CD and boot up from it. Even if you have plenty of RAM, a single broken bit can ruin the whole thing. There's also a scenario where you just have to remove and re-insert all the RAM sticks from the motherboard due to static buildup - it would cause the computer to not do anything when you press the power button.
If all of these still don't work, and you say you have absolutely no video output, it could be a problem with the power supply, processor or motherboard. The only way to check is to test replacements for each - replace the power supply and try turning it on, then replace the CPU and try, then mobo (though it's a lot of work).
Good luck
Aug 06, 2009 | HP Compaq Presario SR1517CL (PX797AA) PC...
I have a Compaq Presario, model #: SR2150NX W/120GB HD
You should be able to add a SATA drive to that machine (IDE should also be available to you). The spec drive in your machine is a 120GB, you may get a decent increase in speed if you use a newer SATA hard drive with a fresh install of Windows on it and simply put the existing drive as the slave or drive 2.
Mar 24, 2009 | HP Compaq Presario SR2150NX PC Desktop
Computer freezes when I connect Logitec web cam
Normal 0 There are a number of things that can cause the computer or the camera to freeze up.
First I’d check to see how much memory is installed in the computer. It takes additional memory to operate the camera.
Hope this helps. Bud
Jan 25, 2009 | Logitech QuickCam Ultra Vision Webcam
I have a compaq presario sr1517cl computer desktop and the dvd is very slow about coming on if at all
Try to Enable DMA in property of My Compter>hardware>device manager>Secondry IDE channel property...
Nov 29, 2008 | HP Compaq Presario SR5010 Desktop PC...
PC with XP pauses at Logo screen on boot up.
how much space is left on your hard drive. when you log on right click on my computer go to properties and check how much ram it is processing. you can also to a complete wipe and format your hdd then reload xp
Aug 20, 2008 | Computers & Internet
Remove arrow from shortcut items
If you are referring to the Shortcut overlay, there are several methods that can remove, replace or customized it.
In Windows XP:
Perhaps the easiest would be to download, install and configure using Tweak UI for XP ;
Alternately, edit your Registry. Expand HKEY_CLASSES_ROOT. Highlight "lnkfile. Delete the Registry Value IsShortcut REG_SZ. Rebbot
In Windows Vista:
Probably the easiest would be to download, install and configure using Frameworkx’s Windows Vista Shortcut Overlay Remover .
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Western Digital My Book Essential Edition...
Hard drive won't turn on
You could remove the drive if you can get the enclosure open and either install it in a new enclosure or as an additional HD inside your Pc. Good Luck.
Nov 17, 2006 | LaCie Big Disk (300872) 400 GB Hard Drive
HP Compaq Presario SR2011WM PC Desktop Logo
108 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
