Question about Acer Aspire 5536-5224 Notebook
Hi , my laptop seems to have crashed , it won't load up I have a black screen with the following writing Broadcom base code pxe-2.1 v1.1.0 Pxe-e61: media test failure , check cable Pxe- m0f : exiting broadcom pxe rom Operating system not found I have turned off over night remove the battery Please help
    Scholar:
  • 88 Answers
Just follow these simple steps below and it should resolve the issue.
  1. When the computer is booting, go in the BIOS.
  2. Change the boot device priority so that your HDD becomes the first boot device.
  3. Disable network PXE boot if possible. If not possible, just put it as the last boot device.
  4. Press F10 to save settings and restart the computer.
  5. If problem is not solved at this stage, turn off the computer.
  6. Remove the lid and remove the HDD, clean the pins and reseat it.
  7. If issue persists, give a tap on the laptop where the HDD is located (I assure this works and has solved many problems) as there seems to be a 'strike zone' on some HDD.
Now turn on your computer and it should be running correctly.
Hope this helps you.
Posted on May 17, 2011
syedmujahed
  • 158 Answers
SOURCE: no boot disk
when this error is showing give me details
mujahed@imsindia.co.in
Posted on Sep 27, 2008
bob_computer
  • 3153 Answers
SOURCE: I brought the computter about month ago.. and now its appears ::
This is a common problem but there may be more than one fix
The easiest is to go to your bios and set the boot device order.
It is quite conceivable that it is set to try and boot from network first
You should select HARD DRIVE or CD DRIVE as you first option and then reverse that order for your second boot device
Posted on Aug 20, 2009
  • 5 Answers
SOURCE: Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Posted on Sep 01, 2009
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Posted on Apr 04, 2010
  • 162 Answers
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Problem with acer laptop. My laptop stopped booting after restart. I just moved my laptop from bed to floor . while in power on the program just crash not responding, then came a blue screen and said...
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. It looks like it is set to boot from a Network or LAN first. You want to boot from the hard drive 1st or the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Acer Computers & Internet
I tried to download windows 7 on my ACER 5351, and near the end the laptop restarted. It came up with this error code : Cannot boot from CD: Code 5. When I took the CD out, the following error code...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 11, 2011 | Computers & Internet
Windows is working normally and suddenly the ideapad Y430 shows a black screen and the following error messages: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C) 2000-2008 Broadcom Corporation Copyright...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 18, 2011 | Lenovo 3000 G530 Notebook
When power is on i get the PXE-E61 code on the screen "MEDIA TEST FAILURE ,CHECK CABLE" after that PXE-MOF code is show "EXISTING BROADCOM PXE ROM ..." my laptop is an acer aspire...
It is trying to boot from the network, basically from the internet cable that can be plugged in. If you enter the bios you can typically disable the PXE boot option so it won't show up again.
May 17, 2011 | Acer AS5741 CI3226 156 3GB320GB DVDR WLS...
Hi my LT Aspire 5536G turned off itself when I was using it. Now when I start it the screen is black with this message - Base Code PXE-2.1 v1.0 PXE-E61: Media Test Failure, check cable PXE-M0F:...
The message you are getting is the laptop telling you it cannot find a boot device. The Broadcom message is the last option in the boot sequence (network boot).
I'm not sure what OS you are using, so the following is loosely based on a standard recovery, PLEASE don't just award a 1 thumb if this does not solve the issue, rather don't leave feedback.
First of all: Boot and press F2 or F10 or del to access the Bios, see that the hard drive is actually seen in the bios, if it is NOT, please repost, this points to HDD failure
Secondly, if it is, in the Bios, set the 1st boot device to DVD Rom. Insert the Windows Disc and IF using XP, wait until it finds the old OS and do a recovery. IF using Vista or Windows 7, its more or less the same, run a repair and if you get the OS back up and running, download a comand line virus scanner such as DRWEB Cure it and run a thorough scan for viruses on the hard drive.
Before condemning the hard drive, try removing it and re-inserting it, see if the bios recognises it.
I'd also advise downloading a disc checking utility to make sure the hard drive is still workable
Jan 22, 2011 | Acer Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
I was using my laptop last night when it just shut down on me, then when i went to turn it back on it goes to the acer "start up" like page before skipping to a black screen and displaying the following...
If you have a BOOT CD then try to boot and go to windows.
Or you can use windows setup CD but go for repair only.
For the future it is a good idea to INSTALL WINDOWS in a USB mini drive and boot the computer from USB. You have to go to BIOS and set USB default drive.
It is a good idea to clone your HD in a CD.
Sep 04, 2010 | Acer Aspire 3690-2196 Notebook
My computer which got on friday is not working, when i start my computer it goes to a black screen. And than this message comes up: Broadcom UNDI PXE - 2.1 v11.4.1 Copyright (C) 2000-2008 Broadcom...
What is your computer brand?
Just turn it on and keep pressing esc or delete or F2 key (depending on the model. But yuo can try any of them. This will take you into the bios screen. In the bios check if hdd is detected. If not - replace HDD>if yes > reset bios to defaults and start recovery (using supplied RDVDs or Recovery partition.
You will find exact instructions in user manual.t
thanx
Sep 14, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 5536-5224 Notebook Logo
354 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
