Question about Samsung 151V 15 in. Flat Panel LCD Monitor
I have a samsung sincmaster 151v flat panal... just plugged it in and screen say " VIDEO MODE NOT SUPPORTED" I try to hit the menu button but nothing comes up...
  • 11,361 Answers
NOT SUPPORTED MODE on my tv screen
Hit source. Change to a different source.
Jul 01, 2012 | Samsung Televison & Video
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
I cannot change my screen resolution
Boot up in safe mode and see if you can change the screen resolution. If not you are being limited by your graphics card (video card) and driver.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. See if you can change the screen's resolution.
If you can't change the screen resolution, try downloading and reinstalling the video driver.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
May 24, 2012 | Dell Computers & Internet
We own a samsung flat screen HD tv, model: Ln46C530, software version: T-TDT5A6SC-10060. At the bottom of the screen there's line of windows that pop up, they say, series 5, wide color enhancer, hyper...
It sounds like you have the Store Demo Mode on. To turn this off, press the volume button. While the volume is displayed in the OSD (onscreen display), press and hold Menu for 5 seconds (or a bit longer).
Alternatively, you can find this in the menu. When TV is the source, press Menu > Setup > Plug & Play followed by Enter. (It's the second choice after Language.)
The manual is available here: http://www.samsung.com/us/support/downloads/LN46C530F1FXZA . This is on page 7.
I hope this helps.
Jun 16, 2011 | Samsung LN46C530 TV
"Video One" displays in upper
Press Mode button to select TV. Then press the Display button. Set the Display to Off (choices are Detailed Mode, Clock, Simple Mode and Off). Pressing Menu should turn off the Display at any time.
Support for the LT-37X688 is available from JVC at http://support.jvc.com/consumer/product.jsp?archive=true&pathId=78&modelId=MODL028191 . The direct link to the manual is http://resources.jvc.com/Resources/00/00/92/YA535ien.pdf .
I hope this helps.
Jun 11, 2011 | JVC LT-37X688 37 in. LCD HDTV
WHEN IM WATCHING TV, ICONS APEARING FROM THE LEFT OF SCREEN ,DISPAYING INFO ABOUT LED TV SERIES THEN ANOTHER ICON APPERARS ECO FREINDLY AND SLIMLINE TV. THEN IT DISAPPEARS AND AFTER A FEW VSECONDS IT...
I do not see a Samsung TV with the model UE40B7020. (What country are you in?) I do have documentation for the UE40C7000WW.
Is the TV in Shop Demo Mode? Press the Info button on the remote to see the mode. If it reads "Store Demo", try resetting it. Press the Volume button on the TV or the remote. While the Volume circle is displayed on the screen, press and hold the Menu button on the TV for about 7 seconds (the remote will not work for this). Home Mode should display on the TV screen.
Alternatively, you can set this from the TV menu system. Make sure that the current input is TV. Press Menu then select Setup (up/down arrows followed by Enter). Select the Plug and Play sub menu and follow the on-screen directions to reset the tv to the Home Mode.
The FAQ for the TV that I used as a reference is available at: http://www.samsung.com/us/support/owners/product/UE40C7000WW#
I hope this helps.
Jun 08, 2011 | Samsung UE40B7020 40 in. LED TV
I am trying to connect a samsung syncmaster 151v to my computer and the moniter reads video mode not supported what am i doing wrong?
Your resolution is set to high for the monitor to accept it. Go into control panel and click on Display then click on display setting and lower your resolution keep going lower until your monitor accepts the resolution size and your monitor should work for you.
I hope this helps you out any positive feedback to me would be greatly appreciated.Thank you
Apr 09, 2011 | Samsung Computers & Internet
The power has died on my Samsung sincmaster 151v. It won't turn on....
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 15, 2010 | Samsung SyncMaster 151 V (Black) 15 in....
Screen don't work when plugged in
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 12, 2010 | Samsung 943BWX Monitor
Samsung 151V 15 in. Flat Panel LCD Monitor Logo
91 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
