Question about ASUS P4P800-MX Motherboard
I have a an Asus P4P800 Motherboard and when I boot up it is giving two short beeps, displays the motherboard screen, goes black, and then does the sequence starting with the two beeps again and again...won't boot up. Any thoughts?
  • ASUS Master
  • 27,725 Answers
First make sure the RAM is securely seated
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 17, 2011
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
Twice beep sound is coming. Booting is not happening for my p4p800 mx/s board
Hello !
If you check out ASUS support, you will find this troubleshooter for the motherboard not booting :
1. Please clear CMOS.
2. Please take out your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Please take the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Please keep the necessary components(CPU, one memory) onboard for a test.
Finally, we would recommend you to replace a BIOS battery to have a test.
Also, by looking over beep codes I have found for AMI BIOS these problems for the 2 short beeps :
1. Memory parity error (Description : A memory parity error has occured in the first 64 KB of RAM. The RAM IC is probably bad).
2. POST fail (Description : One of the hardware tests have failed).
If you have done those and it still doesn't boot, let me know I'll try to find other solutions.
All the best !
Aug 03, 2011 | ASUS P4P800-MX Motherboard
Motherboard power is on but cannot display screen, the monitor is black or no screen.
your problem could be almost any of your hardware components
the best way to detirmine wich one/how to fix it is with a process of illimination. You should do this by switching your hardware components with known good ones.
being a display problem the order i would test with is this.
  1. disconect everything but the screen
  2. swap screen for a known good one
  3. disconect graphics card and try the onboard (if no onboard try another gc)
  4. test psu (power supply unit) this can be done with either a psu tester, multimitre or try with another psu
  5. try removing all your RAM, when you boot if your system beeps a couple of times you know that your motherboardand cpu are good. if it doesnt beep it is probably your motherboard or cpu.
Oct 14, 2009 | ASUS P4P800-MX Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
Won't boot
unplug the power cable (black thing on back) and replug it in after about 20 seconds. make sure the power switch on the back of your pc is flipped to the on position. when you turn your pc on, if the motherboard is getting power, there should be a green light that comes on on the board.
Jun 26, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Will not boot with Keyboard and mouse plugged in
Did you try removing each memory module individually... Instead of just moving them around.. because the error you are receiving is a bad memory error code.
Jan 30, 2009 | ASUS P4P800-E Deluxe Motherboard
My computer does'nt boot
Check your Cooling Fan. Sounds a LOT like the fan is getting Sluggish and not cooling the Board Properly.
Jan 20, 2009 | ASUS P5LD2 Motherboard
Asus p4p800-x no screen no beep
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Aug 04, 2008 | ASUS P4P800-X Pentium Motherboard
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Apr 02, 2008 | ASUS A8N-SLI Deluxe Motherboard
ASUS P4P800-MX Motherboard Logo
198 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
