Question about Electric Garden
Am replacing belt on a bosch rotak having difficulty removing bearing from drive shaft
  • 1861 Answers
SOURCE: right side axle shaft support bearing removal
Change the whole axle. You will waste TONS of time trying to change that bearing, and it is virtually impossible for a guy to do it without a real good machine shop. Trust me. Change the whole axle.
Posted on Sep 12, 2008
  • 512 Answers
SOURCE: Pinion Bearing
the only way to replace pinion bearings is to remove the differential. you shouldnt have to remove the bearing to replace the seal
Posted on Nov 18, 2008
Chiefnadc
  • 71 Answers
SOURCE: Remove the Center Support Drive Shaft Bearings
use a cutting wheel and cut through the bearing as far as you can without damaging the drive shaft.Then get a big hammer and a chisel drive the chisel into the cut and break the bearing.
Posted on Jun 25, 2009
jasperoni
  • 203 Answers
SOURCE: removal of drive shaft
It will cost more money for the special removal and instllation toll than the job itself. It is apercision bearing and it requires a special tool-remove the drive axle,brake rotor,caliper and e-brake shoes. remove snapring and **** bearing out of hub with tool.
Posted on Jul 08, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
How do I remove the cracked positioning lever from Bosch Rotak 34-13 lawnmower?
very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
Jun 22, 2016 | Garden
Will not complete cycle all the time, make a noise like not getting good power to run
Highly possible that the belt is slipping and you will need to replace them, In the first place remove the back cover and check the movement of the drum , if there is friction you will need to check the bearings and the drive shaft. If you observe a slack belt or one which move freely when tugged, then you need to replace it.
Check this link for tips. How to replace the belt on washing machine Bosch
Sep 04, 2014 | Siemens WFXD5200UC Front Load Washer
Manual for bosch rotak 36 mower
contact the seller or go online to Bosch to see if they have extra manuals posted online. Or ask customer service for help.
Jun 06, 2014 | Bosch ROTAK-320 LAWN MOWER FOR 220 VOLTS...
Lawnmower electric
In most cases its not worth to invest TIME if you have a rotak 40 or so , because of the low quality of Bosch mowers its because of they have take over qualcast brand from England they are now owner , the last years there are mowers that have a belt drive from electric mower ROTAK i have replaced a belt but its takes so many thinking and working time to split and rebuild after that the bearings are also not fresh enough to let it be whats over when its over with the bosch mower get an other brand I've never been in working misjudged restoring so, one machine mainly perform the standard excess tension on the belt which the bearing to excessive heat, the stuff is made to break down. i have this year 20 years behind me in repairing also Bosch powertools and thats not only the problem that its BOsch , no its the Qualcast quality that fits the last years inside the bosch brand. the last 7 years the Bosch powertools are differend by model and price and from bad to perfect. but the most common problem is the working time that you will have on a green rotak mower. if you own a old model Bosch fore 8 years ago then the parts are sometimes difficult to get. difficult to place an correct answer but be warned if its handling a rotak .
Apr 05, 2014 | Bosch Saws
BOSCH Rotak 36 keeps stoping
Before all first call upon any additional warranty in case of this (in Qualcast manner made) machine.
Do not self service without tools on this product , it cost much time in almost all cases , all was made by an marketing technical price so you can only the best advice by the dealer or it will not succesful in any case of the time and price .
Look some links on the rotak group mowers.
I do not servicing BOSCH mowers anymore because of the time and price for parts and the short rest time ONLY THE DEALER can help you.
The abnormal beltdrive tension is always the great problem that is for shure on the rise on (almost) all models of rotak serie.
some models have not even nominal value bearings on all parts .
BOSCH
May 31, 2017 | Washing Machines
I need insruction BOOK for Bosch Rotak 344 GC LAWNMOWER
Here you go:http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/Rotak34_manual.pdf?db=ocsr55_s041&item=OCSHEIMWPDF.v$m$d$lobvalues.r55&id=90005,10446,20&filename=Rotak34_manual.pdf
Just copy and paste that into your browser it will take you straight to the pdf for it.
Jul 03, 2012 | Garden
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
Aug 19, 2010 | Toro Garden
Replace front wheel bearings
The bearings in your car are pressed into a hub. If the part is available as an assembly, it can be replaced that way. Generally on a front drive car:
Remove wheels and brake calipers
If it is pressed in: remove the rotors, disconnect the drive shafts and remove the steering knuckle. Then the old bearing is pressed out and the new one pressed in with a machine shop press. If the bearing is part of the hub, that will be unbolted and the new one swapped.
On a scale of 1-10 difficulty, Id rate it a strong 7
Jun 20, 2008 | 1998 Nissan Sentra
Garden Logo
246 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
