Cell Phones Logo
Posted on May 17, 2011
I have a Cobra Timekeeper Answering Machine. The lights on the MEMO and ANSWER buttons do not stop blinking. The messages could not be deleted. How can I fix this? Thanks, Dixie
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Mar 11, 2008
SOURCE: deleted messages
Nope, once they are gone, they are gone.
Paul C.
  • 68 Answers
  • Posted on Dec 09, 2008
SOURCE: deleted a message on vtech digital answering machine
Unfortunately, once a message has been deleted, there is no way to get it back.
Anonymous
  • Posted on Apr 28, 2009
SOURCE: How to retrieve answer phone messages
try pressing intercom 777 then I think
Anonymous
  • 508 Answers
  • Posted on Jul 07, 2009
SOURCE: Retrieve a deleted message from my V Tech answering machine
to late!!! :(
Anonymous
  • Posted on Jul 25, 2010
SOURCE: Lucent Digital Answering Machine Model 1715
If you search for an AT&T Digital Answering machine model 1715, you will be sent to a free service with an abreviated manual.
Answering machine model 27958 GE1- A records message but does not play the message. nothing happens when the memo button is depressed. how can I resolve?
Press the PLAY/STOP button to hear the messages. When you press the MEMO button, the system waits for you to leave a message.
If you need a manual, you may download a copy here. The message playback instructions are on page 33, the MEMO button is described on page 34.
2answers
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
I have a Voca phone RT-250- It does not play back messages. The answering machine plays the recorded message - it records that three messages are there but then doesn't play back the recorded messages.
Need more info here, does the machine record a memo? Set the machine to answer mode and press the little memo button on the very rhs of the machine to start and stop recording.) This should leave a message like through the phone line. Will that play back? Lift the tape lid and see if the tape moves??? With a little more info I can help, I've been repairing those for many many years.
How do I retrieve my voice mail when I'm away from home?
this instruction may help you , if not a model number could help , but try these instructions . thanks
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 57).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following chart:
Remote Commands
Command 0 then 1
Repeat a Message*
Command 0 then 6
Answering Machine On
Command 0 then 2
Playback Messages
Command 0 then 7
Memo Record/Stop**
Command 0 then 3
Skipping a Message
Command 0 then 8
Greeting Record/Stop**
Command 0 then 4
Deleting a Message
Command 0 then 9
Answer Machine Off
Command 0 then 5
Stop Operation
Command 1 then 0
Help Guidance
we can get a link to your manual if we had model number
1helpful
Philips CD135 Twin cordless
press bottom left button and then hold down 7. display will show 0-0 to indicate its turned on. 2 to read messages. 3 to skip to next messge. 4 to record your message. 5 to listen to current welcome message. 6 to delete messages. 7 to activate answer machine. 9 to deactivate ans mach. 0 to record internal memo. To use any of these functions bottom left button must be pressed first.
15helpful
6answers
Howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
37helpful
2answers
Uniden answering machine model 900MHZ
Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
4) Enter a command within 15 seconds, each command there after must be entered
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
