LG front loader wd1238c error code IE - Washing Machines
3 Suggested Answers
techbuster
  • 5081 Answers
SOURCE: what does IE error code on LG front loader mean
"IE" is an error code that indicates a water inlet problem on an LG washing machine. This code will appear if the washer is not filled to the correct level within eight minutes after switching it on. Possible causes for the IE code include partially closed taps, improperly attached inlet hoses or clogged inlet hose filters.
Posted on Jun 21, 2010
rickead1
  • 1998 Answers
SOURCE: LG WD1238C front loader water is leaking out of
The cause of this is almost always something blocking between the outlet of the dispenser housing
usually it is the large hose that goes from the dispenser to the top of the tub itself if you remove the 2-3 screws along the back of the machine and slide the top cover towards the rear of the machine and then remove the top cover completly this will give you access to this area Usually you will find a large soap deposit or debris stuck in this hose or near the outlet of the soap dispenser housing itself . You have to remove the top cover in order to physicly clean and check these areas if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Jun 21, 2011
My LG Wd1238c front loader machine wont turn on, plugged in but nothing even turns on..
You have a dead control board that will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 28, 2012 | LG WM-2277HW Front Load Washer
Have a load of washing in my front loader and now my LG wasing machine says 'UE'. What does this mean and how do I fix it?
is this an Lg washer ie error code is an water inlet error machine notices low water pressure , you either have kinked fill hoses , plugged screens in fill hoses coming to you watervalves or watervalve is damaged from foreing debris coming into watervalve .........
Jan 24, 2011 | LG Washing Machines
Code UE
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
LE (with a a slash in the
middle of L. Thermister out
CE: Over amping
LE: hall sensor short
bE: Ball sensor loose connection
EE: eeprom out
PF: power failure
Service manuals for LG front loaders
Dec 26, 2010 | Kenmore Elite 45986 Front Load Washer
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
