Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
I have had the mower for about a year. Since I have owned the mower it leaves a trail of grass beneath the center of the deck. I have taken it to a toro dealer to check out the blades and deck and they cannot find anything wrong. Help
  • 407 Answers
Sharpen the blades,very sharp,and lift the deck one notch from where you normally cut.Some times the blades will get dinged,or the ends of the blades will dull.
Posted on May 17, 2011
Mower leaves strip of grass unmowed in center of deck. This is a model X300 with newly sharpened blades
Check the center blade to make sure it spins freely when the deck belt has been removed. The spindle may have frozen up.
May 26, 2016 | John Deere Garden
The mower leaves a trail of grass on the inside line of the left front or the under cutter deck
sounds like the blades need sharpened or may be wore out. possible belt slipping.
Feb 10, 2016 | Garden
How do I replace the blade belt on a ranch king lawn tractor?
Turn off the mower completely and clean out beneath the deck with a mower-cleaning tool to remove any built-up grass deposits. As debris collects inside the deck, the blades can't move freely and you'll have unusual patterns or unevenness forming in your lawn as a result. The mower-cleaning tool scrapes this debris off and restores the deck to proper function.
Measure the height of the mower deck with a ruler when the mower is on flat ground. The deck should be an equal distance from the ground on all sides to ensure an even grass cut. Adjust the leveling bolts on both sides of the deck as needed to readjust the height until it's even. If the mower hits something like a rock or a large stick while mowing, it may knock the deck off balance.
Inspect the deck for any dents or warping. Use a rubber mallet to carefully straighten any dents in the deck if the deck is metal. Plastic decks generally need replacement if they crack or warp.
Remove the deck for a more thorough inspection or cleaning as needed. Remove the grass catcher and take off the pins or mounting bolts holding the deck in place. Lower it to the ground and pull it out from under the mower. Unhook the cutting blade from the underside of the deck with a wrench and set it aside.
Sand off any rust with sandpaper and use the mallet or a hammer to eliminate any remaining dents or warps.
Reinstall the deck once any corrosion or dents are fixed.
OBD Tools 365 Days Shop
Sep 15, 2014 | Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
Aug 23, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
314 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
