Question about Haier HDN655E Dehumidifier
The humidity reading on the setting screen reads "Lo". What does that mean?
  • Haier Master
  • 43,501 Answers
That just means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
It will not run when showing that...
heatman101
Posted on May 17, 2011
  • fidler11 Jun 10, 2011
    I've got the same issue. But in my case the humidity level is much more than 35% and device is still working. Moreover it does it well, still dehumidifying the air pretty efficiently. Is there a problem with the humidity sensor or I should replace some fuse? The strange thing is that when I put the humidity percentage rate setting it holds the levels precisely, so it seems, that the machine determines the moisture after all. Otherwise, how it could be possible to work so fine?
    Do you have any suggestions?
    Best, Oleg
  • D. Floyd Kolb
    D. Floyd Kolb Jun 10, 2011
    On some dehumidifiers the dashes represent a continuous run mode ... I think that is the case with you unit...nothing wrong with the unit..
Humidity display window always LO
I would go to a box store and get a guage that displays relative humidity and see where it settels at. Your humid may actually be low.
Apr 11, 2014 | Amana 45 Pint Electric Dehumidifier -...
Goes on.... humidity % registers 70 but in just a minute or 2 it begis to decline and ends up at Lo which then wont pull water from the air. I know it is humid, some sensor must be getting fouled up.
70% is not what the dehumidifier is removing. It's what it is maintaining. Which is extremely high humidity. To lower the humidity level in the house lower it to 35%. That will remove a large amount of humidity over a fairly short (4 hours) period of time. If you have an analog unit (no LED Screen) set the humidity extraction knob on Maximum, which is 35%.
Keep in mind, dehumidifiers work the opposite of what you think.
Hope this helped you and thanks for choosing FixYa..
Sep 16, 2011 | Dehumidifiers
I've been reading the other questions on this website. Like many others, our 54501 dehumidifier turns on and all controls still work. We just cleaned the filter but it does not collect water. I read...
No, it may mean that you don't have the humidity extraction level set low enough. The lower the setting, the more humidity it will extract. Try setting the extraction level at 35%, to see if the compressor turns ON.
If yours is being used in a basement, the ambient air temperature at floor level is between 40 - 60 degrees. Dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air temperature at floor level is colder than at shoulder level in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
I hope this helps you further troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 25, 2011 | Kenmore 54501 Dehumidifier
WE have a model DE45EJ - T. The humidifer is not pulling in anything or making any noise or doing anything at all. It says Lo in the bottom reading.
The "LO" in the bottom reading, Indicates the current humidity extraction setting. If the unit was operating properly not that long ago (A couple of hours), the reason it is not doing anything, maybe that there is no humidity above "LO" = 30% at this time. Once it the humidity level rises above 30%, it should turn ON and function normally.
Also, was the timer set to turn the unit OFF at a specific time?
If the unit wasn't working properly a couple of hours ago.
Check the air intake filter for excessive dirt or clogs. Turn the unit OFF & unplug it before removing the filter. While the unit is OFF, remove the bucket, empty it if needed and carefully replace i, making sure it is fitted properly in to it's holder.
Air obstruction: The dehumidifier requires an minimum of 12" to 18" clear air space around the entire unit.
Hope this has helped you further troubleshoot and solve the problem. To assist you further, in case you have misplaced yours, I am including a link to your Owner's Manual that you can download and print for future reference. http://www.haieramerica.com/en/asset/product/4ba7175e54
Jun 22, 2011 | Haier 45-Pint Dehumidifier
Unit will not run and the code 'LO' show up. What does the 'LO' code mean?
Hi, it simply means that the humidity level is lower then 35% the lowest setting on the dehumidifier...
Jun 09, 2011 | Haier 45-Pint Dehumidifier
"Lo" reading at humidity setting
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end. if this helps please rate me.
May 17, 2011 | Haier Dehumidifiers
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
May 16, 2011 | Frigidaire FDF50S Dehumidifier
The dehumidifier cuts off when it is set on 70% as soon as the compressor cuts on. i can leave it on lo and it runs.
If you're setting the humidity level on 70 % , that means you want to leave the relative humidity in the house at 70%. That's why the dehumidifier is cutting off. Your house is already at 70% humidity or higher. If you want to remove humidity, set the level lower. If your trying to make it cooler in the house or remove a lot of moisture, set it a 35 to 45%.
Hope this helped solve your problem.
Apr 16, 2011 | Kenmore Dehumidifiers
The dehumidifier wont work even the lights was on and it show Lo all the times and we do not know why it happen and how can we get it fixed as we live in Oshawa, Ontario?
I found this on the web
Q - Will my dehumidifier work in a cold room ?
A - A dehumidifier will not operate satisfactory in a room that is below 65 degrees F. At this temperature it will become necessary to operate the dehumidifying coil below freezing temperatures in order to reduce the relative humidity to a reasonable valve. Frost on coils usually will appear.
I would imaging that the humidity is already lower than the dehumidifier could get it down to. that's why it reads "Lo" on the display.
Jan 10, 2011 | Haier 45-Pint Dehumidifier
Humidifier stopeed working
You have a bad fan motor. Put your hand against the grill to see if there any air movement. You need to buy a new fan motor assembly, it is attached by two long
bolts, easy to swap, except the wiring may not be easy. May have to cut the 3 wires and resolder. Get to the motor by removing the back panel and then the fan. Removing the fan may not be easy, they put some gunk on the spidle thread.
The cheapest price I have seen for the motor is $27-$28, shipping about $8 and tax
about $1.5.
Sep 18, 2006 | LG Goldstar LD65EL Dehumidifier
Haier HDN655E Dehumidifier Logo
249 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Vincent Cruz
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
