Question about Samsung DV316LES Electric Dryer
My dryer's barrel will not turn. I have replaced the pulley and belt but that did not fix the problem. The pulley's tension is not tight enough to turn the barrel. I have the correct barrel and pulley. The problem started when I was getting clothes out of the dryer and turn the barrel manually and heard a pop. I thought I had broken the belt but that was not the case. I check to make sure the motor was still in running condition it works fine. Once again something broke that will not keep the belt tight. Thanks for your help.
  • 150 Answers
Hello Mwagner, sounds like the Idler bearing pulley assembly has come loose from the belt. It's job is to keep tension on the belt so the motor is able to turn the dryer drum. By watching some videos online it seems that alot of teardown is required to get to the part you need to inspect and or replace. Here is a link for you to look at that might help you. Samsung Dryer Idler Pulley Roller Replacement DC97 07509B
Posted on May 04, 2017
  • 41 Answers
SOURCE: samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: Email address:
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
Posted on Jul 01, 2009
  • 20 Answers
SOURCE: dryer stops after 2 min run
change its thermistor.
Posted on May 23, 2010
  • 1056 Answers
Dryers have thermal fuses that goes out. Unplug the dryer and check all the thermal fuse for continuity with an ohmmeter. A good thermal fuse would read very low reading in fractions of an ohm.
Posted on Jul 19, 2010
  • 43501 Answers
SOURCE: dryer power is on, cycle starts but dryer drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Posted on Nov 11, 2010
  • 3 Answers
SOURCE: replacing belt in samsung dryer I cant get the
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same.
If they are the same route the belt per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Hope this helps!
Posted on Dec 01, 2010
I have a squeaky dryer
You have a belt that goes around the barrell and the belt has a tension pulley on a tension arm. Those pulleys go bad. It is an easy fix. It takes longer to get to the pulley than to fix it. It is a 4 minute fix, but it will take a while to take off the housing to get there.
May 08, 2015 | Frigidaire FER641FS Electric Dryer
How to replace an air conditioner compressor and tensioner
The screeching noise is of course the belt traveling faster than the pulley it is around, in other words it's slipping. Hopefully you have a worn belt, it takes quite a bit to pull a compressor. Assuming that the compressor is in working properly and your belt is good, look at the tension pulley. I had a vehicle once that did the same thing and after a lot of "try this" didn't work I got a new tension idler pulley and it fixed it. The old one wasn't putting enough tension on the belt to hold it tight enough to pull everything. Since then I have ran into several that were so weak they wouldn't hold proper tension. Just something that is overlooked a lot of times because he belt seemed tight enough. Just one more thing to try, hope it's not anything with the compressor because as you know they like those compressors and want give them up cheap.
Jul 15, 2012 | 1999 Chevrolet Silverado 1500
Tensioner pulley doesn't turn in my dryer
Try to turn the pulley by hand. If it is frozen up you will need to replace that assembly.
Jun 20, 2012 | Dryers
The dryer is making a terrible noise, and the drum has stop turning. How many belts are required? when lifting the top and checking the belt should there be any play between the belt and the drum?
Only one belt is used ,their should be no slack between belt and drum.If you can lift up the belt and it dosent snap back tou have a tensioner problem , that could also be part of your noise concern
good luck
Aug 08, 2010 | Magic Chef CYE3005AYW Electric Dryer
The dryer is getting power but the barrel isnt turning
If motor runs but no tumble, belt is broken. It broke due to overloading, old age, or bound up tension pulley or drum support wheels. You have to check all of these when replacing belt. Belt is fairly cheap.
Jul 02, 2010 | GE Profile Harmony DPGT750EC Electric...
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
The barrel on my Amana dryer has stopped turning. I took it apart. The belt is still in tact and tries to turn it. How do I tighten the tension on the belt? Can it be done without removing the barrel...
i believe most dryers have an automtic belt tensioner on them usually at the top or bottom at rear of drum it is a possibility that the belt has just stretched beyond adjustment if it is real old or the tensioner is damaged and not adjusting properly they only move in up and down position just to keep belt tight and they are usually spring loaded
Dec 26, 2009 | Dryers
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
Belt tension
there is a spring-loaded belt tensioner pulley. make sure it is part of the belt loop. you will need to move the tensioner pulley against the spring force then place belt on tensioner pulley and then release the tensioner pulley and belt will now be tight.
Sep 12, 2007 | GE DLSR483EE Electric Dryer
Samsung DV316LES Electric Dryer Logo
55 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
