Question about Blackhawk HELICOPTER DIECAST UH-60 BLACKHAWK 160 SIKORSKY
I need the uh60 rotor blade dimentions describing the trim tab width
What are the dimentions?
Width: 32 - 44
Depth/Length: 37 - 38
Height: 30 - 39
Aug 15, 2014 | Jonathan Louis Grady Accent Chair
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
How do I remove the coin tray from my sr5toyota hilux
My '04 Toyota Hilux cup holder came out as follows... You need to start by removing the dash trim that surrounds the instrument panel and air vents, as per the following. Looking through the steering wheel to the instrument panel, remove the two screws above the instrument panel window. Then remove the two screws under the steering column. Then carefully prise back the section of lower trim to the right of the radio, you will see another screw, remove this. The instrument trim is now free to be wiggled free from its clips. You will need to disconnect the lead to the digital clock. You can now remove the whole dash trim which contains the housing for the cup holder and place it on a work bench. If you then look down onto the sliding tray (from above) you will see two squareish tabs. These tabs are the limiting tabs preventing the tray from sliding out (under normal use). What you need to do is slide the tray out wards and using a flat screwdriver lever these tabs downwards as you pull gently on the tray. You should do one side at a time, so push one tab down until the draw is free on that side then while holding the draw steady repeat for the next tab. Once the two tabs are squeezed free the tray will slide out. With practice I suppose you could just pull the tray straight out (without removing the dash trim) by interting two hacksaw blades curved slightly upwards throught the front of the (open) tray to squeeze the tabs as you pull the draw forward but you need a little luck and knowledge of where the tabs are... And besides, removing the dash trim is pretty simple. With these instruction it should take no more than 10-15 minutes start to finish. Good luck!! Mike
Aug 18, 2012 | Toyota Hilux Cars & Trucks
Exact Outside Width Of The Ge Jx2127sh Microwave Trim Kit. Does anyone know the exact total width of the GE JX2127SH Trim Kit? None of the GE sites list the outside width.  Extrapolating from the cutout...
I would go with it. The 1/8" on each side you are worried about can probably be trimmed if need be. The manufacturer is usually very precise on an measurements they publish.
Dave
Jul 04, 2017 | Microwave Ovens
What type of motherboard do I need for a acer veriton m661
you need m.b intel Q35/31 / G41 intel chipset mini m.b
  • dimention around
    Height: 14.4"
  • Width: 7.1"
  • Depth: 17.4"
    if use the same case
  • Jan 04, 2012 | Acer Veriton M661 PC Desktop
    I have a Singer Ultarlock 14U34 and need to know how to adjust the stitch width.
    You can download a manual from this link
    http://www.singerco.com/uploads/download/664_14u34b,234b.pdf
    Check page 16, changing the seam width is done by moving the cutting blade left or right and using only one needle. So if you want the narrowest seam, use the right needle only, remove the left one, and move the blade as far left as you can. Your manual says to turn machine off at the wall for safety, many overlockers will have a motor cutout when you open the front covers, but its good practice to turn off too. Then you put pressure against the upper moveable blade and swing it up out of the way and make adjustment to the lower fixed blade with a screwdriver in your kit (some overlockers it is a knob you move to move the blade position).
    And reverse for a wide stitch, use left needle for 3 thread wide seam, and move the blade far right.
    You can also use the 4 thread seam where you use both needles and trim up narrow but the seam will be heavier than a three thread.
    Each time you make changes to the amount of fabric being trimmed, you may need to finess the upper and lower looper tensions to ensure the seam is tensioned enough to just meet on the cut edge of the fabric. This is the norm for overlockers, each fabric will behave a little differently so you need to test stitch and adjust a little. Your manual will explain this process too.
    Sep 05, 2011 | Singer 14SH654
    How do I change the stitch width on my Bernette serger?
    You move the top blade to the right to trim less so stitch forms wider and use left needle. Or both needles for 4thread seam which is more for knits. Blade has a knob usually to adjust it's position. You should test on scraps of your fabric as the weight of the fabric will also determine width of the seam. Adjust top and bottom looper tensions to encase cut edge neatly.
    Apr 23, 2011 | Sewing Machines
    What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
    All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
    In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
    In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
    And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
    Do not forget to rate, please.
    Mar 12, 2009 | Watches
    Removing interior door trim '93 suzuki swift
    Assume you have been able to remove window winder.
    The surround of the the door handle (interior) is clip on at four points. Tabs are about an inch in from each corner and slide over a plastic nub to lock in place. . Start at top right corner. Get a small flat blade screwdriver with blade horizontal and gently - repeat gently, prise tab upwards while applying gentle pressure away from door and pushing slightly upwards. Tab should just slide off nub holing it in place. Do same for other side on top tab. Gently wriggle downwards so bottom tabs disengage. Installation is reverse.
    Sep 14, 2008 | 1993 Suzuki Swift
    Grinder support
    They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
    Aug 27, 2008 | Speed CGW ABRASIVES 35606 "24 GRIT" HIGH...
    Blackhawk HELICOPTER DIECAST UH-60 BLACKHAWK 160 SIKORSKY Logo
    42 people viewed this question
    Top Blackhawk Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Blackhawk Toy Expert? Answer questions, earn points and help others
