Question about Whirlpool Duet GHW9150P Front Load Washer
Making a grinding sound
After I push start, the door locks but there is not the usual filling with water sound. Instead it sounds like a grinding like sound. I tried to unplug and reset but that did nothing. Please help!
  • squirrellady Aug 19, 2008
    Third repair for grinding noise...Remove top panel. Look to left rear..rotating arm that gets stuck. Give it a nudge, but do expect this to continue...part on order (back order) My machine is only two months old, but not used much because we went on vacation right after buying. Disappointed in this machine.
  • Anonymous Sep 16, 2008
    I HAD this same problem. Turns out there was part of a pen stuck in the pump. The technician left. Next load, same sound. Once the other part of the pen was removed from the pump, no more problem.
  • 4 Answers
I had the same problem. Turns out there was part of a pen stuck in the pump. First load after the technician left, same problem. Once they remove the rest of the pen still in the pump, problem no longer exists.
Posted on Sep 16, 2008
Will not start to fill with water
have you switched the water ON
Jan 25, 2014 | Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
Machine will not fill the door locked sign
Sounds like could be fill solonoid valve faulty or water turned off..
Jan 23, 2010 | Hotpoint WMA54 Front Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
Washing machine
THAT GRINDING SOUND is coming from the main motor , first you have to check a CAPACITOR located near the motor , disconnect it and try START AGAIN , IF it still giving you the grinding sound check if its coming from the motor , if so youre gonna need to replace it , cause the motor come from the factory SEALED ,making it imposible for repair,hope this helps AJ
May 06, 2008 | Kenmore 22422 Top Load Washer
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
