Question about Garden
Procedure for setting idle, etc for 18" homelite chain saw
  • 43,501 Answers
The best thing you can do is to dump all of the gas out that you can and then run the saw till it runs out of fuel...oil the chain good while your running the gas out and your good...
heatman101
Posted on May 17, 2011
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Races at idle
If the idle cannot be controled by the idle screw ( screw marked with an I or T on the side of the carb ) then you may well have an air leak through a crank seal or a gasket.
Nov 23, 2012 | Homelite UT10580 18-Inch Gas 42cc Chain...
My Homelite 46 cc 18" chainsaw has a very high idle. How can I fix that?
Turn the idle speed screw (not the H and L jet needles) CCW until the chain stops turning, but the engine continues to run. Hope this helps!
Jul 18, 2010 | Poulan Pro Chain Saw 46cc 20"
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
How to stART HOMELITE 18 INCH TIMBERLINE
Make sure you have fresh fuel mix in the tank. Pump the primer bulb about 6 times or less until the bulb draws fuel into it. This fills the carburetor with fuel. Close the choke and set the fast idle if the throttle trigger has a button near it--otherwise, operating the choke auto-sets the fast idle. Don't operate the throttle again until the engine is running. Turn on the ignition switch and pull the engine through smartly. It should start within several pulls. If nothing happens, then get back to us for some troubleshooting help. Hope this gets it running!
May 07, 2010 | Homelite ZR10926 16 Chain Saw
New Homelite 16" chain saw is difficult to impossible to start.
Read and follow the start procedure in the manual, most say to open the choke once the saw attempts to start. Most operators miss this or do not hear the cough and flood the saw. Your manual is probably similar, if not successful with the following maybe time to return it. One thing that might impact starting, what is your elevation? Your saw was setup at near sea level, if you 4000' it may need an adjustment. The store where purchased will probably recommend someone if asked.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 02, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What length chain is needed on homelite 360 proff. overall bar length 22" 19"from front of saw (extended)
What is written on the Bar? If your Bar is a 22" then the chain will be packaged for that length Bar. Make sure you get the correct model chain for your saw.
Jul 02, 2009 | Oregon Scientific Oregon Chainsaw chain...
I have a homelite chain saw and is out of setting.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
May 01, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
