Question about Yamaha RX-V459 Receiver
Hello i have a yamaha RX-v459, and i have an HDTV, can i connect my cable box to the yamaha and the yamaha to the TV and get HD? the Yamaha does not say HDTV, does that matter, or will i still get HD?
    Brigadier General:
  • 8,546 Answers
Yes, the cable box should/could be treated as any other digital audio device. The video could also be run directly to the TV as it doesn't actually improve from being routed to/through the Yamaha, does it?
The labeling on a given input is irrelevant (except for "PHONO", which is literal and exclusively for a turntable).
Posted on May 18, 2011
Testimonial: "Thanks!"
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.9_9_2012_6_50_32_pm.jpg
Sep 09, 2012 | Yamaha RX-V361 Home Theater Receiver
I getting noise in yamaha rx-459 please help.
I used to get noise as well. It turned out to be that one of the cables to the speakers was loose. Try tightening the cable connections to the Yamaha and to the speakers.
Mar 01, 2011 | Yamaha RX-V459 Receiver
Where do I plug rca cables from the cable box into an RX-V2500 Yamaha receiver?
Depending on what type of connections your cable box has available you can do the following:
1) If yo only have the standard VIDEO & L R AUDIO connections you can use the DTV connection on the back of the V2500. If your cable box also has an S-VHS connection this would be the same connection to use.
2) If you have COMPONENT VIDEO connections on your cable box then you would still use the DTV connection. Looking at the back of your V2500 the regular DTV RCA connections are just to the left of center. Farther over to the left are the COMPONENT VIDEO connections. They are labeled Y, Pb, and Pr. These allow for the higher needs of HD TV transmissions. If your cable box has these connections then making use of them would allow for the best quality for your picture.
The following website has your manual available for download in case you need it:
http://www.devicemanuals.com/guide/Audio%20and%20Video/Yamaha/Yamaha-RX-V2500-Owner%27s-Manual-TVRBek9UVT.html
Please let us know if you need any further assistance with your issue.
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
How do i connect my xbox 360 to my yamaha rx-v665 receiver
If you are gonna connect the x-box to the yamaha directly you would have to connect the red and white cables to one of the inputs on the reciever and the yellow to the video on your tv.
Feb 16, 2010 | Yamaha RXV665BL Receiver
YAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Dec 17, 2009 | Yamaha RX-V459 Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Vocals missing while playing with 2 speakers
Go to the amp "Basic Setup" and alter basic setup according to
- the size of the room (details in the manual)
- alter the no. of channels e.g. if you have only 2 front speakers, change the channels to 2.1 (.1 for the subwoof)
- Once the setup is changed, the amp pumps in sound according to the set up
All the best
Apr 25, 2008 | Yamaha RX-V459 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V459 Receiver Logo
222 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
