Question about Performance Teknique ICBM-9192T Car DVD Player
ICBM-9709 installed and works, that is until I switch on the lights. When lights are turned on i get an error "CAR" with a symbol next to it and unit stops functioning.
Currys essentials dishwasher error warning
Just installed a CDW60W16 at my daughters house. worked ok empty but as soon as it was loaded the glass icon lit up and beebs. when I turned it over to take a look at the float switch I noticed that the levelling legs were all screwed in so the base of the machine was sitting on the floor. so when the machine was loaded the pressure switch operated as it was being pushed up by the floor. I unscrewed the legs a few turns to allow an air gap between the floor and base of the machine and all working fine now. on checking the installation instructions it only mentions loosening the legs to level it if required which is wasn't. maybe the manual should give instructions to unscrew the legs a few turns to prevent this
Aug 24, 2012 | Dishwashers
HOW DO I RESET THE TIRE PRESSURE LIGHT ON DASH,I CHECKED THE PRESSURE AND ITS ALL GOOD AND I DONT HAVE THE BUTTON IN MY CAR
there is a button on the left hand side of your turn signal lever that says bc. there is also a button on that switch that can be pushed up and down. start your car finger up on the small switch on your turn signal until you see the tire light symbol. once you see the symbol in you instrument cluster press the bc button once then hold it until it says resetting. drive the car and the light will go off in a matter of minutes maximum.
Aug 11, 2010 | 2008 BMW 3 Series
C45072 Kenmore washer will not start. Did one
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Cheers!
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Performance teknique icbm-782 amplifier will not power on
run 12 volt into your rem terminal and see if it comes on if it does your remote wire coming from the headunit is bad or cut
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Sub amp not working anymore
sounds like a typical case of poor conections causing the amp to fail... take the cover off of the amp. Inspect where the terminal blocks meet the circuit board. SOmetimes you can repair it sometimes its just too far fried..
Sep 18, 2007 | Performance Teknique ICBM-772 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Lexmark E232 photoconductor
Make sure to install the new photoconductor 1st.
1) Power off the printer using the switch in the back.
2) Open the front cover.
3) Press and hold the Continue button (Big silver button with Diamond shape symbol) and power the printer On (turn the switch back to ON).
4) When you see the last light i.e. error light on solid, release the Continue button and close the front cover.
5) When you close the cover you will see all the top 3 lights on solid.
6) Press the cancel button with X symbol for 4 times very slowly till you see toner low light (i.e. second light from top) on solid.
7) Press the continue button and wait until you see the light sequence.
8) Press the cancel button and wait until you see the light sequence.
9) Finally power off the printer using the switch in the back (IMPORTANT= wait 1 minute) and power it back on to exit the configuration mode.
Nov 07, 2006 | Lexmark E232 Laser Printer
Performance Teknique ICBM-9192T Car DVD Player Logo
138 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
