H79 Themescene projector does not come on - it's as if the fuse has blown but changing it doesn't fix it.
  • thomasversmi
    thomasversmi Mar 08, 2012
    I have the same problem..
    Solution ?
2 Suggested Answers
SOURCE: ThemeScene HD65 projector, red thermometer light is on
I simply shut the projector down (had to pull the power cable) and when starting up again it was working fine and has since then.
Posted on Oct 05, 2009
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
Optoma Themescene HD72i - Color wheel glass loose
Dear David,
i have Optoma projector HD72I color wheel,
please patiently wait for some days, once i post it on Ebay, i will inform you at the first time.
lets keep in touch with freely,
best regards,
Jack
Nov 14, 2011 | Optoma HD72 Multimedia Projector
Optoma h79 wont power up is there a fuse to replace if so where is it thanks
hi,
All electronic equipments have fuse in the power supply section.
In your projector it is inside the unit. The fuse of projectors will blows only if there is any trouble in the power supply. Just try to replace the fuse in the power supply board. It will be near the input connector. If the fuse again blews then you have to replace the power supply board. Because the components in a projector power supply is rearly available. You will not be able to access the fuse with out oppening the projector.
OK
Oct 08, 2011 | Optoma H79 Multimedia Projector
My car doesn't have a fuse diagram and my hazards and turning signals don't work. I bought fuses but don't know which one to change.
just pull them all out one at a time till you find the blown one .but if all fuses all ok then change the hazard warning light switch as this is the most likely unit to fail and cause these problems
Sep 26, 2011 | 2001 Ford Mustang
Stereo is hooked up, but not receiving power. wondering if it might be a blown fuse, and how do i fix this?
just check all your fuses with a test light because even if the fuse doesn't look like its blown it might be. also check wires behind the stereo
Jun 30, 2011 | 2000 Ford Contour
Dell DLP projector won't turn on. Does anyone know a fix?
have you changed the lamp recently, or cleaned the air filter.
The internal fuse may be blown, or a whole lot of other things may be wrong, so we need more information otherwise it's off to a technicain to check it out.
Mar 17, 2011 | Dell 1100MP DLP Projector Multimedia...
Need pc driver for h79
http://diplodrivers.com/search.php?keyword=pc+driver+for+h79+
Dear this link can give you proper drivers if still you could not find drivers then send me a massage i will again send you some other links my brother is a great hacer and i have sent my request to him to find drivers for H79
Thanks
Feb 15, 2010 | Optoma H79 Multimedia Projector
Oct 03, 2009 | Optoma HD65 DLP Projector
Optoma HD65 bulb only 108 hrs old having difficulty starting up
Use the warranty! since you anly had it for 8 weeks, and the waaranty last for one year, go back with it and get it repaired or get a new bulb. A buld last at least 2500 hours, in eco mode it last for over 3000 hours.
Good luck to you
Dec 17, 2008 | Optoma H30 Multimedia Projector
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
