Question about Ovens
Is there a fuse or re set button on my neff combo micro wave, ive just cleaned it and now have no power to it, i have checked the fuse
    Scholar:
  • 52 Answers
ISOLATE THE MICROWAVE DO NOT OPEN AS YOU CAN RECEIVE A SHOCK FROM THE INTERNAL CIRCUITS.
Check the mains fuse in the plug, remove fuse and put into a working appliance, if it works. Buy a new microwave, as the internal circuit has a fault, and depending on model, the cost of repair is usually very expensive. Unless you have an appliance insurance. leave repairs of this type of appliance to the proffs.
Check the door is closing properly, as a switch is activated by the colsure of the door, some cheaper microwaves use plastic and this can fracture, causing the microwave to not work. The front display should light up regardless of the switch position. The fuse inside can be 10 to 15amp slow blow, if this is the case, scrap the appliance as it requires specialised equipment to fault find and carefull handeling discharging capacitors and so on. A reasonable level of knowledge of electronics is required. hope this is of assistance.
Johnf1
Posted on May 17, 2011
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
My neff oven b1322.1 is showing c03 code since moving , I now can't set the timer and clock etc can anyone help to solve this?
The C03 error indicates that the timer button is stuck or not responding. Check if the buttons can move freely; you may need to remove the rubber cover by prying it up. If the buttons move freely, sometimes the error can be cleared by unplugging the oven (or turning the unit off at the circuit breaker) for several minutes (up to 30 minutes). Turn the power back on. Then press and hold the Timer button for more than 180 seconds (3 minutes). Some people have reset the timer by setting the function selector to "interior light on" instead of pressing and holding the timer button.
If none of these actions work, then the timer clock needs to be replaced. If you add a comment with the full model number of your oven, I may be able to give you the part number. NEFF doesn't list a B1322.1; there are several B1322N1 models. There will be addition numbers in the model number and there may be some extra letters as well. See http://www.neff.co.uk/store/spare-parts to get a picture of where the rating plate is for your unit. That will have the full model number.
I hope this helps.
Oct 01, 2016 | Neff Ovens
The main oven does not heat up ! although the fan comes on and the interia light works. Is this reparable ?
Check the auto/manual function. Might be set to come on at some random time at night, these things happen when buttons get bumped while cleaning :)
Jul 29, 2010 | Neff Ovens
How do i reset the oven after a power failure?
If your oven won't heat at all, the most likely problem is a blown fuse or a burnt out element. Assuming you're not attempting to repair an antique, your oven will have a clock. If it has also stopped working, it's safe to assume the oven is not getting electricity. Check your circuit breaker box and reset the breaker if necessary and see if this fixes the problem. If not, cut power to the oven at the breaker box before going any further. Note that your oven runs on 220 volts. There should be a double switch on the circuit breaker board controlling power to it. If not, there will be two single switches that need to be tripped to cut power to the oven.
Even if you didn't find a blown circuit breaker, the problem could still be a blown fuse. Some older ovens have their own set of fuses located under the range top, in the back of the oven space, or behind the oven. Inspect the fuses and replace any that have blown with one of the same amperage. Your oven might also have a circuit breaker with a reset button on the control console or on top of the oven that needs to be reset.
If you are still confounded, pull the oven away from the wall. If it is a range/oven combo, make sure it is plugged securely into the wall. If it is a stand-alone oven, inspect the wiring in the junction box to make sure everything is tightly connected and the wiring doesn't show any signs of damage.
Apr 07, 2010 | Neff B1421 Electric Single Oven
Neff U1524 Double oven
Your oven should be connecting individually to its own fuse in the fuse board.
Jan 03, 2010 | Neff U1721 Double circotherm Electric Oven
Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Feb 27, 2009 | Neff B1641 Single circotherm super...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
Clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Feb 06, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
83 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
