Question about Whirlpool Calypso GVW9959K Top Load Washer
Display-it's stuck- no error codes it's just stuck
When loading the washer..I went to turn it on and on the display it's stuck...No error message..on the display the timer says 6 minutes water stuck on hot and it's on hand wash..We have un-plugged and re-plugged the machine still will be stuck..when you un plugg and re plugg it will act like it's turned off then you hit start and there it is again stuck you hit cancel/stop and looks and sounds like it's going to cancel out but it does not the display is still stuck. Any help in how we can fix this as it will take 2 weeks for a repair guy to come out just to look at it!! Thank You
    Novelist:
    Champion:
  • 261 Answers
Need a control panel
Posted on Sep 04, 2008
2 Suggested Answers
ssebata paul
  • 159 Answers
SOURCE: Display-it's stuck- no error codes it's just stuck
check senser
Posted on May 30, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Error codes???
Hi DMS1, your wacher might have gotten stuck with somthing. Maybe a piece of string or just dirt.
Have you already tried to open it and clean it?
Dec 29, 2007 | GE WCVH6260F Front Load Washer
My 3 1/2 yr old unit stopped working completely at almost the end of the cycle. When I went to take out the clothes they were still wet, thought it was the spin cycle so I tried that and the machine...
Hello Anne, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the issue could be related to the door switch or control board. However, first let's try recalling the error code by waking the unit and wait approximately five seconds. Then press and hold CANCEL and START/PAUSE key at the same time. Error code should display. With the error code I can help you determine the possible failures.
If the washer does not display an error code, reset the washer. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes, turn the unit on and redo the steps above.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
Sep 25, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire LTF530FS Front Load Washing Machine. It stopped draining and spinning. The drain pump had an underwire from a bra stuck in it. We removed that and cleaned the pump. Hooked everything...
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Since you hear a humming noise, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 28, 2012 | Frigidaire FTF530FS Front Load Washer
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
My machine has a code and is full of water
can you provide the full model # and also the full error message?
Sep 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
276 people viewed this question
Dan Webster
Dan Webster
Sal De
