Question about Citizen Eco-Drive watch
I am looking for a manual for a Citizen Signature Grand Complication Eco Drive Watch
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
escapement
  • 2334 Answers
SOURCE: setting time on my citizen eco drive skyhawk model jr3090-58l
Go to this site and choose interactive settings for your watch:
http://www.citizenwatch.com/COA/English/find.asp
Do not forget to rate, please.
Posted on Jan 19, 2009
escapement
  • 2334 Answers
SOURCE: CITIZEN BL9000-59F MEN ECO DRIVE WATCH minute repeater
Try this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Everything you need for the caliber number and settings is here.
Posted on Feb 24, 2009
  • 47 Answers
SOURCE: date setting in a citizen eco-drive calibre 8700 watch
http://www.youtube.com/watch?v=RF3hC1hgZz4
hope this link illustrates u better
All the best,
Prince
Posted on Aug 06, 2009
escapement
  • 2334 Answers
SOURCE: need to shorten my band
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
How o set my watch to the correct time date and day please my watch is a citizen eco drive wr 10 bar
Setting Instructions - Citizen Watch - English (CA)
www.citizenwatch.com/en-ca/support/setting-instructions/
  1. Cached
  2. Similar
Need additional assistance? Our support team may be reached at: 1-800-461-4189 8:30AM - 5:00PM EST, Monday - Friday customerservice_ca@citizenwatch.
[PDF]instruction manual - CITIZEN WATCH Global Network
www.citizenwatch-global.com/support/pdf/8720/e.pdf
  1. Similar
Visit the Citizen web site (http://www.citizenwatch-global.com/) to view visual guides for ..... Eco-Drive watch handling precautions ... Water resistant to 10 or 20. citizen eco drive wr 10 manual - Google Search
Apr 06, 2017 | Citizen Watches
I am desperate to find an owner's / instruction manual for the Promaster SST Citizen Eco Drive watch.Please TELL ME A PHONE NUMBER I CAN USE TO OBTAIN THIS.
To determine the exact model and specifications of your Citizen Eco-Drive, flip the watch to the reverse. On the case back will be extensive information about your timepiece. You're looking for the "movement caliber," a four-character combination of letters and numbers, separated from the seven-digit "case number" by a hyphen.
Next step, visit this links:
- citizenwatches.com.au/instruction-manuals
- citizenwatch.com/COA/English/settings.asp
Hope this helps (remember to rate this answer).
Apr 14, 2011 | Citizen Eco-Drive watch
I would loke a operating or instrution manual for citizen eco dri
mcdevito75 here, BEST BET contact Citizen at www,citizenwatchserv.com use the contact likk on that website.
Jul 11, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Had battery replaced
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please .
Apr 08, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
The second hand doesn't move . i tried pushing the buttons in the chronograph mode, the time mode and nothing. i have a citizen eco-drive BL5260.
I assume that you do not have any instructions for this watch.
If you enter "www.citizen-signature.com/#/settings/" you should arrive at the page for your watch.
You can download the manual or look at sections.
Feb 22, 2010 | Citizen Perpetual Calendar BL5260 50E...
Citizen Eco-Drive
Could be that the watch inside and outside numbers do not match. If the dial says Eco Drive, that should be the first step. Next, find out about the 4 digit number that tells you which type we are looking at. You may want to open the back and look at the number on the watch internals. But be aware you may damage the water proof seal in doing so.
Really, you should write down all numbers you can see and send an email to citizen. They will help you.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Jun 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Problems setting my citizen eco-drive perpetual calender
Apr 29, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco-Drive  watch Logo
273 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
