Question about Ovens
Prestige built in fan oven for no reason keeps tripping the fuse was working good till about a week ago
    Scholar:
  • 52 Answers
ISOLATE FROM MAINS SUPPLY BEFORE CARRYING OUT TESTS
Remove oven from unit, remove back visual inspection of wiring, this should take about 30 mins.
Several makes of ovens use heat temp control components, usually mounted on the frame or back of the oven, inspect, if there are signs of heat around the component replace. When oven is switched on is the fan blowing air when the door is open, if not very strong remove fan and clean with WD40, make sure this is dry before fitting again. If fan appears to be working correctly, a heat element could be faulty, inspact when the fan has been removed it should be mounted in front of the fan. If there is black spots, not food build up, it is more grey to black, replace the element, you should be able to get parts from white goods .co.uk. Without more info I am unable to help.
Hope this is helpful
Johnf1
Posted on May 17, 2011
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
My Prestige PR1 S0 oven suddenly stopped working. I checked the socket it was plugged into. No power when other electrical item (radio) is plugged in. I plugged the oven into a gang socket which was...
It sounds as if the oven element short circuited and tripped the oven circuit. You will need to reset the oven circuit breaker or rewire the fuse at the switchboard.
If the oven indicator light comes on when you turn the oven on you will need to replace the faulty oven element.
Feb 23, 2011 | Ovens
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
Smeg oven suk92mfx5
ring element has burnt out.
Feb 16, 2008 | Ovens
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
