Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer I have a Maytag gas dryer (about 2-1/2 to 3 yrs old) that the timer doesn't work. It will dry laundry turns on and off but it will not shut off automatically, seems as if the timer is bad. I bought and replaced the timer selector switch but still will not work.
  • 943 Answers
Hi thanks for the question i would check the venting on this dryer make sure its clean if you can vacuum the entire dryer this will solve your problem thanks the appliance doc
Posted on Sep 18, 2008
My Maytag MDG640AWW gas dryer timer does not advance and auto shut off. What part number do I need to replace this part?
my best guess is a restricted vent, disconnect dryer vent hose and run dryer, it should work if not then there a few other things, here is a link that will help you:
http://www.hometips.com/repair-fix/laundry-dryer-timer.html
Mar 13, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Automatic drying doesn't shut off
its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
Feb 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
126 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
