Question about Hotpoint WD62 Front Load Washer / Dryer
Fixing of door hinge?
How to fix a door hinge on WD62 hotpoint?
Plz help
    President:
  • 1,462 Answers
Undo screws holding both halves of the door togethet then hinge can be removed. hinge is just held onto the cabinet with a couple of screws
Posted on Oct 02, 2008
Hotpoint Aquarius fdf784 door won't close think it's the hinge gone
suggest fix hinge or contact supplier for replacement.
Sep 18, 2016 | Hotpoint Washing Machines
Replace a door on a hotpoint washing machine
http://www.espares.co.uk/advice/washing-machines/a/7/1296/how-to-fix-a-broken-washing-machine-door-hing.html
Hi go to the above espares page where you will find a video on how to replace a door hinge, should show you enough to enable you to replace the door. There are other videos on how to replace the door interlock and release mechanisms as well.
Hope this helps, if it does please remember to rate me
May 04, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wd62 had to bang door to make it work, now stopped altogether could it be knackered interlock.
In a word 'yes' and glad you know our technical jargon!
It calls for a call- to your local service engineer unless, that is, you can change it?
Good luck,
John C
Feb 27, 2011 | Hotpoint WD62 Front Load Washer / Dryer
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
WD62 DOES NOT CYCLE THROUGH ITS PROGRAMME
hi, this model is notorious for programme faults and i would suggest you change the controller, hope this helps
Feb 09, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 W/D. Works OK empty but bangs when full
Sure easily. Plug off the wall, open up behind to check if any springs have come off, check the shockabsorber, bolts.
Feb 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
143 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
