Question about John Deere Garden
Bought a used John Deere lawn tractor. Used it 3 times and today it won't start. Checked battery and date Oct. 2008. Bought and installed new battery. Insert key, step on clutch and "nothing" What am I doing wrong? Gas tank is full and oil check good.
  • 417 Answers
one of the safety switches probably came out of alignment, probably the safety switch at the pto blade control. its an electric switch up under the frame usually. there are a few of these switches on riding mowers and just one of them will stop it. check your seat switch to make sure its functioning. a word of advice. these switches are backwards of what you would think they would be, meaning when the switch contacts are apart, it will start and when they are closed or together it wont. if switch seems to be working unplug the electrical connector off the ignition switch from the rear and see if its rusty, plug it back in. check your battery connections for rust, check all your contacts for rust and sand them down.
jm .
Posted on May 17, 2011
  • Jude Meredith
    Jude Meredith May 23, 2011
    a clarification- okay theres two important circuits here. starting and running. the starting circuit has to have the contacts closed together to start the engine, the spark plug circuit must be an open circuit to keep the engine running. the PTO switch is usually a combination ignition kill( (running) and starter kill switch and the seat switch usually is just the ignition running) circuit by itself.
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
I used my John Deere L110 Lawn Tractor all day yesterday. Turned the engine off, it popped. Then went to start it today and it just pops, seems like the timing is off.
throttle down your engine before turning it off . this reduces amount of fuel going into a hot engine ,just a few seconds before switching key off , should stop back firing issues.
Sep 09, 2013 | John Deere L100 Series
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
Lawn Tractor will not start
check for power at the solenoid then put power to the small terminal at the solenoid and see if that turns it over then check the the safety switches
May 20, 2012 | John Deere Garden
Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Apr 27, 2012 | John Deere Garden
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
239 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
