Question about Frigidaire Freezers
Very hot to touch compressor, is it safe? - Frigidaire Freezers
    Sergeant:
    Champion:
  • 257 Answers
It's safe but not efficient You probably need to clean your heat displacement coils. (Black Coils) under or on the back side of refrigerator. Use a refrigerator coil cleaning brush and scrub thoroughly. Use a vacuum and hose to **** up the dirt. Hope this works out for you . Thanks
Posted on May 17, 2011
  • 110 Answers
Compressors do usually get a bit warm during operation, but unless you left the door open for an extended period, or cooled warm foods in your freezer, the compressor would periodically run, then stop and cool off. If you observe your refrigerator for a while and notice that it is running much more than usual, it may to be serviced, possibly to look for a coolant leak or other similar issue.
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
My compressor is really hot
If the compressor is almost too hot to touch, then you have a concern and need a repair technician. It is normal for the compressor to be a little warm, but not too much where you cannot keep your hand there.
Jul 20, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Sep 02, 2011 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
My freezer is working fine, but my compressor is hot to the touch. Is the compressor too hot? I have converted my freezer to a kegerator with a temp. regulator. I do not want to burn my house down or...
the compressor will run hot,but you should be able to touch it without burning yourself.(when you compress a gas, heat is generated as it turns to liquid and when it expands back to a gas it absorbs heat,the principal of a fridge...)
Oct 23, 2010 | GE Freezers
Compressor very hot on Kenmore 7.5 c.f. upright freezer. It is too hot to touch and smells like burning paint, but stayed cold inside. Wondering if this is a bad compressor and about how much it costs to...
Compressors will normally run hot to the touch, but should not have a burning smell. If the compressor does need to be replaced you would be better off getting a new freezer. Compressor replacement with the labor can run into more than a new freezer.
Aug 27, 2009 | Kenmore Freezers
Upright freezer hot to the touch on the sides.
inspect the unit for a fan near the compressor not to be alarmed some do not have a fan if so insure that it is running while the compressor is running also some defrost problems will cause this the unit runs for a long time heating the compressor and by way passing the heat along
Aug 13, 2009 | Freezers
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Whirlpool fridge and freezer will not cool
Replace the start relay on the compressor.
Jun 08, 2009 | Whirlpool Freezers
Avanti CF61 does not freeze
Bad compressor. check the compressor with the unit on with a volt meter and see what voltage you are getting and also if it way to hot to touch by hand is another sign compressor is bad
Feb 09, 2009 | Freezers
Freezers Logo
75 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
